No luck with my setup
2000 miata normaly aspirated
stock injectors
LC-1 Wide band
GM IAT
Adaptronic 3bar MAP
Adaptronic ECU installed as per Steins threads
Using stock injectors 3bar map from a couple users her to include Travis
Started the car with first map and nothing cracked and crancked but no start. Then switched to a diffrent map from one of our users. The car started with idle fluctuations of about 500 rpms. Then went to MAP sensor calibration and hit learn lower values, this caused the oscilations to fade out for about 20 seconds till engine died and never started again. Im recharging the battery and hoping for a miracle...
stock injectors
LC-1 Wide band
GM IAT
Adaptronic 3bar MAP
chris101
10-09-2015 09:08 AM
JesseTheNoob
09-30-2015 02:44 PM
