Valve cover project - PICS
Old 03-15-2010, 03:22 AM
Bannisheded
railz's Avatar
Total Cats: -3
Default Valve cover project - PICS
So continuing to want the cleanest look for my engine bay I went and started on a new project earlier tonight involving the valve cover. Its just a new cleaner way to securely hold your COP's with out using the ugly metal sheet everyone else uses to hold there COP's down.
Pics go by steps taken.
I'll let the pictures explain now:
you will first have to remove the middle plate underneath the valve cover to remove the metal shavings.
Here I set the cop how I wanted it to be held down. used a screw driver as a punch to mark where to drill the hole.
shown is the tap (thread size 1/4) but you can use any and some long screws that will be later cut to size.
holes are now drilled and tapped. Test fitted everthing and it looks good!
The plan is to cut and remove the head of the screw and have it at the perfect length, Use red loctite on the new threads made on the valve cover, The loctite should create a good seal so no oil leaks out of the new threaded holes. Reinstall the plate that was removed and ad some wrinkle paint for a clean fresh looking valve cover. For the nuts being used for the screws i,ll be using the nylon locking type.
So obviously i'm not done yet. It was getting a little late so I called it a night. Once I finish working on it tmrw i,ll post pics of the finished product
railz is offline
Old 03-15-2010, 03:54 AM
timk's Avatar
Total Cats: 37
Nice idea! Maybe a good idea would be to turn the bolts upside down, feed them up through to the top of the valve cover then two nuts with Loctite to hold it in place? This is assuming the bolt heads aren't going to foul on anything in the head...
timk is offline
Old 03-15-2010, 03:57 AM
Bannisheded
railz's Avatar
Total Cats: -3
I was originally going to do this but if you look closely at the last picture you'll see that the screw holes are right up against the wall of the sparkplug hole so no way the head of the screw would fit =(
railz is offline
Old 03-15-2010, 07:05 AM
timk's Avatar
Total Cats: 37
Ah, I see. Bummer!
timk is offline
Old 03-15-2010, 07:59 AM
ArtieParty's Avatar
What ugly metal sheet? lol
Piece of aluminum between the cops and the valve cover. You screw the cops into that instead of drilling into the valve cover. You just use the valve cover bolts to hold the aluminum piece in place.
ArtieParty is offline
Old 03-15-2010, 12:48 PM
johnmatt's Avatar
Nice work. I was thinking about doing the same thing
johnmatt is offline
Old 03-15-2010, 01:21 PM
p51hellfire's Avatar
yea I agree with artie have you looked at the write up on the cops??? Brain shows you how to make a nice plate that goes under the cops..
p51hellfire is offline
Old 03-15-2010, 01:34 PM
Boost Pope
Joe Perez's Avatar
Total Cats: 6,587
Very, very cool.
I'd been wanting to do this exact thing when I built mine, but couldn't bring myself to drill the VC for some reason. Wound up with something similar to Artie and P51, using a piece of 1/4" thick bar:
On the backside, I countersunk it to drop down over the raised edges around the bolt holes in the VC. I also countersunk the backside to accommodate four upwards-facing flat head machine screws, such that they sit flush with the underside of the bar. On top of the bar, I put two nuts down over each screw, to hold it in place and set the height of the COP, and then one acorn nut over each COP holds it in place and provides a stock-like appearance.
Joe Perez is offline
Old 03-15-2010, 02:19 PM
Bannisheded
railz's Avatar
Total Cats: -3
I know about the plate...This is the whole reason why i drilled holes and used screws
it looks cleaner then the ugly metal sheet you all use
railz is offline
Old 03-15-2010, 02:58 PM
turotufas's Avatar
Total Cats: 7
I'm contemplating my future setup. Might use the jbweld method to fasten the COPs.
Looking forward to your results.
turotufas is offline
Old 03-15-2010, 11:55 PM
cardriverx's Avatar
Total Cats: 12
looks good.
it also has the benefit of the COP boot actually covering the spark plug hole, which it does not when you use an aluminum plate like a lot of us do.
cardriverx is offline
04-12-2021 04:21 PM
bigmackloud
01-08-2021 11:24 AM
09-30-2018 01:09 PM
Quick Reply: Valve cover project - PICS
