-   -   new source for pump (https://www.miataturbo.net/methanol-water-injection-22/new-source-pump-20899/)
JasonC SBB May 13, 2008 11:22 AM
new source for pump
2 Attachment(s)
From Autospeed
Ulka E5EX coffee machine pump, used in Espresso machines, made in Italy. ~Au$110 in Oz.
It's a magnetic piston pump like the Aquamist. Looks like Da Bomb.
Oh it takes 120 Vac or 240 Vac so you'll need a >50W inverter for it.
wes65 May 13, 2008 11:40 AM
So, you seem to have a lot of suggestions for parts. Maybe a writeup is in order? :D
Zabac May 13, 2008 11:50 AM
Yes Jason, please combine the information to make sense to the nOObs.
magnamx-5 May 16, 2008 12:12 AM
That pump will only flow enough to meet my needs at 0 psi dude i would keep looking
there should be better stuff out there. At the pressure most WI systems are designed to run it would only flow about 200cc/min wich is notvery much watter and i would want alot more headroom for anything i ran idk maybe it is just me.
JasonC SBB May 17, 2008 02:01 AM
How much pressure do you need?
cjernigan May 17, 2008 02:17 AM
Pretty sure most guys run their sureflo pumps between 75 and 100 psi.
Joe Perez May 17, 2008 11:28 AM
Let's back up for a second, here.
I honestly thought this was a joke when it was first posted. I'm still considering it to be in the troll category, rather than a serious solution.
Forget for a moment about flow rate and pressure, we're talking about having to build or install an inverter into the cars electrical system and run 120VAC wiring through the vehicle. Who here thinks this is a better / safer / more reliable solution than a simple 12Vdc ShurFlo pump? I mean, what are the supposed advantages of the expensive coffee maker pump?
cjernigan May 17, 2008 11:31 AM
Only one I can think of is size but even though its smaller once you build the converter and mount it all up I bet it takes up the same amount of room as a well packaged sureflo.
91NApeewee May 19, 2008 09:33 PM
With the price of the DO kit, why hassle with making one. I was going to build my WI system but its going to be cheaper just to buy one.
On the other hand, good job on taking the DIY initiative.
devilsown May 27, 2008 06:30 PM
yea, would be nice if we could get a smaller pump to preform worth a damm.
ZX-Tex May 27, 2008 09:11 PM
A lot of the sizing of these types of things are driven by the laws of physics. A reasonably priced (non-NASA space probe component costs) 12VDC, water/meth compatible pump that performs reliably like the shureflo pump... is going to be about the same size as a shureflo pump.
Higher voltage more or less means a smaller motor, but as said already, you need an inverter, which means more mass/volume/complexity.
magnamx-5 May 28, 2008 12:08 AM
You probably could but the cost of mats would be pretty high.
JasonC SBB May 30, 2008 08:09 PM
I disageree, the Shurflo pump has way more volume flow capacity than needed.
JasonC SBB May 30, 2008 08:10 PM
An inverter that can drive this pump can be bought for $20 and is about the size of a pack of playing cards.
JasonC SBB Feb 1, 2010 10:51 PM
$55
Chris Coffee Service - Ulka Vibratory Pumps EAX5 52 Watt
$64
120V Ulka Vibratory Pump - Espresso Machine Vibe Pump - Espresso Parts
Pump curves:
Google Image Result for http://cs2.kompass.com/images/catalog/KBD/10004613/10004613_cat01_00004_f.jpg
JasonC SBB Feb 1, 2010 11:01 PM
Datasheet:
http://www.ulka.it/admin/moduli/m003...g_ULKA_web.pdf
