Differential torque specs
How tight should the diff pumpkin be attached to the aluminum carrier on a 1.8 rear end? Just snug?
Thanks |
enough.
1. apply sealant to the housing face
2. tighten the bolts 13-19 ft/lbs. |
thanks, I couldnt find those specs anywhere
I just posted in your thread on CR.net. My '95 FSM says 17-19 ft/lbs, but you get the general idea.
I tightened it to 25ft/lbs according to some old ass book my dad had. probably woulda been smarter to check for exact specs on here, but whats done is done. holds good too, no leaks and none of the bolts / threads broke
| All times are GMT -4. The time now is 10:15 AM. |
