-   Meet and Greet (https://www.miataturbo.net/meet-greet-40/)
-   -   noob questions (https://www.miataturbo.net/meet-greet-40/noob-questions-36665/)
swimming108 Jul 1, 2009 11:59 PM
noob questions
Hi guys,
i have been on this forum for a while now. Mostly lurking and reading. I have never dealt with a turbo system before and figured that this would be the best location on the forum for some easy questions. I have slowly gotten my miata to a point where i feel that i am ready to add that turbo that i so sorely want.
At the moment i have about $2000 to spare.
I already have a GM IAT sensor, and electronic boost controller kit from DIY Autotune. I also have a boost gauge. Everything else that i have done is listed in my sig.
I am looking at buying begi's shanghi s turbo system with the following options...
-bypass valve
-oil pan drill and tap
-mild steel separate gasses downpipe
-ceramic coating on the manifold
-wb o2 bung
with this i was going to order a 3 source vacuum fitting for the wg, map, and boost gauge
will this get me started out, running 5psi?
what other odds and ends am i missing?
would i benefit in the future by splurging on extras like stainless steel dp, braided lines, or heat shielding?
my future goals include...
-larger injectors 460 or bigger
-ebay intercooler kit
to run 10-12 psi.
Would it be possible for me to easily switch to an external WG setup in the future with this kit?
Thanks for helping me with my shopping list.
-Jared-
miatalover Jul 2, 2009 03:06 PM
Does anyone have any info on this?
Stein Jul 2, 2009 03:15 PM
That should get you going. You can add the rest later. I made my own heat shield. I don't know what they charge for one, but it is a good idea.
Mild steel DP is fine. I mean, what do you want, a lifetime DP or a 5+ year DP?
Some would argue for braided right off the bat. Again, I didn't but was careful with routing and protecting lines from heat. I also slid some spare 5/8" silicone lines over my water lines for extra abrasion and heat protection.
budget racer Jul 2, 2009 03:17 PM
Looks like he has the adaptronic
Stein Jul 2, 2009 03:28 PM
Yeah, I ninja-edited that before I saw your post.
swimming108 Jul 2, 2009 06:42 PM
thanks guys,
the heat shield is $89... I know that i can beat that price if i do it my self, but the quality would probably suck.
I like that trick with the coolant line inside another line, i think i will try that. This will definitely leave me with more money to put toward an intercooler or injectors.
BTW: Stein, how do you like your 600cc injectors? How much did they set you back?
