-   -   100% Meth (https://www.miataturbo.net/methanol-water-injection-22/100%25-meth-37919/)
JayL Aug 8, 2009 01:43 PM
100% Meth
Anyone in the Miata community running 100% methanol yet or is everyone still using a 50/50 mixture?
SKMetalworks Aug 8, 2009 01:49 PM
There is a thread that's going on that someone had there WI nozzle had disintegrated the screen.
You get your bung welded? I haven't got a call from Andre yet.
kotomile Aug 8, 2009 02:00 PM
No one that I know of in the Miata community, but my EVO buddy uses 100% meth in his Aquamist kit and swears by it.
JayL Aug 8, 2009 02:02 PM
I've been following that and it doesn't concern me.
The bung is in and I'm going to finish the rest of the installation today hopefully. Mounting the tank is the biggest issue that I'm having so far, I just can't come up with a mounting solution that is functional and looks professional.
I'll be down at the shop either Monday or Tuesday and will ask Andre.
SKMetalworks Aug 8, 2009 02:03 PM
Tie downs? I was going to use some straps and screw them to the trunk so its nice and tight. You could use a belt :giggle:
leatherface24 Aug 8, 2009 03:19 PM
im using about an 20 water 80 meth right now with no problems. it actually works great
Joe Perez Aug 8, 2009 03:31 PM
Why?
I mean, if your injectors are undersized and you need to add fuel that's one thing, but in terms of cooling, the specific heat capacity of water is about 4.12 kJ/kg/°C vs. only 1.40 kJ/kg/°C for Methanol.
SKMetalworks Aug 8, 2009 05:19 PM
Injector issues is none existant. Its the octane bump that he wants. Right now he runs race gas and needs some more timing for cheap!
IcantDo55 Aug 8, 2009 05:28 PM
Originally Posted by Joe Perez (Post 440126)
Why?
You are a genius and I know that so that said; the cooling capacity of the liquid is based on how fast it evaporates because evaporation is the process that causes cooling so why would the one that evaporates faster not cool more? I just alwats though that if it evaporated faster it cooled better.
"Changing liquid at one temperature to vapor at the same temperature, requires that the "latent heat of vaporization" be supplied from somewhere. This energy comes from the surface that is doing the evaporating."
Question - Evaporation is different in different liquids why is this?
Also why does evaporation cause a cooling effect?
The evaporation of a liquid depends upon its vapor pressure -- the higher
the vapor pressure at a given temperature the faster the evaporation --
other condition being equal.
The higher/lower the boiling point the less/more readily will a liquid
evaporate.
The amount of energy required to convert one mole of liquid to one mole of
vapor, the more energy is required for evaporation. You can find some
interesting trends in these behaviors by perusing a handbook such CRC/s
Handbook of Chemistry & Physics.
Water is a unique liquid with regard to its vaporization properties. It must
absorb ~10 k.cal/mol of heat at 25 C to convert one mole = 18 gm = 18 ml of
water to vapor and of course must release the opposite amount of heat for
the opposite process.
Cococarbine3 Aug 8, 2009 05:33 PM
Which would have more knock suppressing capabilities when adding timing? 100% water(cooling), 100% methanol(octane), or a combination?
SKMetalworks Aug 8, 2009 05:52 PM
In for the answer!
M-Tuned Aug 8, 2009 07:03 PM
I plan on running 100% meth on my system. I have a bunch of old Nitrous nozzles, Selenoids and jets and I plan on using them to inject the meth into my intercooler pipe.
I just need to get a nice big tank and a meth safe pump.
I want it for the extra Octane and cooling...
JayL Aug 8, 2009 08:20 PM
Well, I went and got 2 gallons of methanol put into a 5 gallon fuel jug. I'm going to start with a mixture of 2 parts meth and 1 part water and see if it gets me to where I want to be.
Then I really started to think about this some more, is all methanol created equal? Since I'm using this more as a power adder than a safety net, this concerns me a little bit.
dc2696 Aug 8, 2009 09:58 PM
We are having the exact same disscussion on my local forum.
100% Meth isn't something to be just fucking around with.
There's some god info in the thread and I'll link it incase anyone wants a read.
dc2696 Aug 8, 2009 10:02 PM
780Tuners Edmonton Car Forums - Water/Meth Conversion Chart
Meth mixing and some insight and opinions
kotomile Aug 8, 2009 10:27 PM
Why?
I totally see your point Joe. I think there are two W/AI injection strategies - to use it as cooling and extra insurance, and to use it as fuel and count on it for tuning. I think those running 100% see it as the latter. I saw an MR2 in Turbo mag once which had two fuel systems essentially, one for 87 octane and the other for whatever hi-test he was running. His EMS switched between the two.
So, if you look at the meth as a secondary fuel source and tune accordingly, it makes a lot of sense. But if you're like me, and a lot of the members here, you're using the WI as cooling and extra insurance against detonation.
If none of that makes sense, I'm sorry, been drinking a bit today.
JayL Aug 8, 2009 11:47 PM
You're right about there being two different groups of people running water/meth injection. I'll come out and say it, I plan on using the meth as a power adder. I've done all I can do on 92 octane pump gas and I need more.
RotaryMiata Jan 21, 2010 05:59 PM
100% Water all the way...
I am Jack's NA Jan 21, 2010 06:52 PM
What about E85?
Jeff_Ciesielski Jan 21, 2010 06:54 PM
Originally Posted by I am Jack's NA (Post 511455)
What about E85?
We don't have a steady supply of E85 up this way. Believe me, if we did, I'd already be on top of that shit :).
