-   Dynos and timesheets (https://www.miataturbo.net/dynos-timesheets-21/)
-   -   1.6 Intercooled Greddy kit 11.7 PSI (https://www.miataturbo.net/dynos-timesheets-21/1-6-intercooled-greddy-kit-11-7-psi-39069/)
ssmith Sep 12, 2009 12:17 AM
1 Attachment(s)
Attachment 203735
Done with LC-1, MS, Water inj at >4psi, 2.5" exh, i/c, 460cc inj.
Was playing timing the whole time, was getting crazy torque readings during a few pulls, (200-220ft/lbs) on a couple.
Spark table still needs a bunch of work, was more conservative than the DIY base map. (knocksense false positives make me nervous)
Pharo_X Sep 24, 2009 05:30 PM
Hi Sam, nice ride.
You may want to lean out the table area between 4500RPM-5500RPM a little more to compensate for the W/I.
Also, start with lower timing and work it up. There's a lot of craziness going on after the W/I kicks in a bit. Is your W/I progressive control?
Goodluck.
ssmith Sep 24, 2009 06:05 PM
Thanks man, that water is just a pressure switch. Changed it to >11psi. Retuned my VE to high 11's above 10psi. And I've been working on a decent spark map with my det cans.
Hopefully this is more than enough to put me in the 200s.
http://i9.photobucket.com/albums/a59...pter/spark.jpg
Braineack Sep 24, 2009 06:58 PM
spark map is a bit retarded, you should be able to get away with 16* at 12psi, which would probably bump you 10-20rwhp.
what sorta muffler/dp?
Ben Sep 24, 2009 07:00 PM
needs moar downpipe and exhaust.
ssmith Sep 24, 2009 07:24 PM
stock downpipe, but goes right into 2.5" all the way out. straight through magnaflow muffler. no cat.
Can I do 16* with CA 91?
Braineack Sep 24, 2009 08:07 PM
needs more downpipe STAT.
Fireindc Sep 24, 2009 08:12 PM
Yeah should help your spool with a proper 2.5 dp. As you already know the stock greddy one is complete trash.
ssmith Sep 24, 2009 08:35 PM
Sounds good, ill get on that asap.
