I slaughtered my Torsen... *video*
Old 09-16-2007, 12:24 PM
ApexOnYou's Avatar
Default I slaughtered my Torsen... *video*
http://vids.myspace.com/index.cfm?fu...deoID=18191701
Strong my ***
If anyone is selling a torsen.. Let me know!
ApexOnYou is offline
Old 09-16-2007, 12:40 PM
patsmx5's Avatar
Total Cats: 475
"Whoops.." HAHAHAHAHA
Damn, that does suck though.. At least you got it on video
patsmx5 is offline
Old 09-16-2007, 12:42 PM
Total Cats: 6,587
Damn dude, never seen one fail like that. Did the ring gear do that damage to the case? But seriously though- LOL at that last comment. "That's a big-*** hole."
Joe Perez is offline
Old 09-16-2007, 12:54 PM
akaryrye's Avatar
holy **** first time seeing that too! that **** sounded good though man
akaryrye is offline
Old 09-16-2007, 01:01 PM
ApexOnYou's Avatar
The line worker that pushed me off the track picked up a chunk of the case for me, and it his impressions of the ring gear in it. I couldnt really see inside, so thats all I can think of right now. I'll tear it apart this week after work to see what happened. I still cant believe the damn thing broke, I allways heard how "strong" the Torsens are..
Old 09-16-2007, 01:04 PM
patsmx5's Avatar
Total Cats: 475
Maybe the ring gear broke, since it should be the weak link compared to the torsen. Hoepefully it didn't take out the torsen with it.
patsmx5 is offline
spike's Avatar
It looks like the ring gear broke.When you get a new diff,get the ring & pinion cryogenic treated before you install it.
spike is offline
Old 09-16-2007, 01:09 PM
ApexOnYou's Avatar
Funny thing is, I was just talking about that, trying to convince my friend to do it when he rebuilds his M3, and it didn't even dawn on me to cryo treat the replacement torsen...
Does anyone know what all it takes for a RX7 diff swap? One of my sevens may have a LSD, and I would be more than willing to sacrifice it for the better of my Miata haha. I haven't researched it at all.
Old 09-16-2007, 01:11 PM
ApexOnYou's Avatar
Im wondering if it would be possible to shoot the ring gear out, and not damage the torsen. Im assuming nothing was spared, it would only take one little tooth off the ring gear getting stuck in a gear on the torsen to ruin it. Plus, the rear end is locked up, which confirms my fears even more..
Old 09-16-2007, 01:12 PM
patsmx5's Avatar
Total Cats: 475
Hey, if you decide to go with a seven lsd you can give me that old torsen you have. If it's repairable, I'll get a ring gear for it.
patsmx5 is offline
Old 09-16-2007, 01:22 PM
ApexOnYou's Avatar
Im hoping its repairable so I can just throw in a ring gear and case and call it a day.
Old 09-16-2007, 01:42 PM
+1 on getting it chryo'd. It's super duper cheap too.
Old 09-16-2007, 02:17 PM
paul's Avatar
i've never heard they were that strong, just that they don't wear out like the clutch types. I have a friend that's broken 2 on his 270hp m2. That's why FM was offering the Guru differential.
paul is offline
Old 09-16-2007, 02:24 PM
sure its possible. unless ring gear got into the torsen and it chewed on it a bit.
Old 09-16-2007, 02:51 PM
neogenesis2004's Avatar
I could see drag racing doing that.
neogenesis2004 is offline
Old 09-16-2007, 02:59 PM
Default cryogenic treatment
I got a couple PM's regarding cryo'ing parts. There are many places that do it, this was the first result generated from a google search
http://www.metal-wear.com/racing_component_prices.htm
Expect to pay $75-100 to cryo a ring and pinion.
The process involves super cooling the item with liquid nitrogen and bringing it up to room temperature again. I am not qualified to give a great explanation, but essentially the extreme cold causes the item's structure to compress in on itself, and when it warms again, material stresses are all but completely removed. It makes the item much stronger and less prone to fracturing.
Alot of folks also cryo their valves, pistons and/or blocks. It promotes even heat distribution.
Old 09-16-2007, 05:28 PM
ApexOnYou's Avatar
An instructor reccomended www.300below.com , they are in Illinois so its close to me. I want to cryo treat my next set of brake rotors.. Curious to see how much of a difference it would actually make.
Old 09-16-2007, 05:43 PM
Total Cats: 2,099
Nothing in our drivetrain lasts at a drag strip.
Savington is offline
Old 09-16-2007, 05:47 PM
miatamania's Avatar
Damn.
miatamania is offline
Old 09-16-2007, 06:47 PM
ApexOnYou's Avatar
Only parts I expected to fail were the tranny and possibly the drive shaft once I start running slicks with launch control, but I never guessed the rear end.
Quick Reply: I slaughtered my Torsen... *video*
