Another oil supply line thread (with Part Numbers)
Hey guys, I just installed my Greddy kit with some custom oil lines and now that I know it all fits I thought I would post the exact part numbers and everything I used in case anyone wants to duplicate it. It's very similar to the part numbers on this thread:
https://www.miataturbo.net/forums/sh...eddy+oil+lines
I used Banjo bolts and -3AN line. I ordered the following parts from http://www.anplumbing.com/
Earls 977515 10mm x 1.25 Banjo bolt $4.18 (for Greddy turbo connection)
Earls 977520 10mm x 1.5 Banjo bolt $4.18
Earls 997631 10mm Banjo Adapter -3 male to 10mm Hole diameter $6.18ea (2 needed) $12.36
ANPlumbing 63010132 -3AN SS line Female swivel both ends, -3 hose, 32" long $14.69
Total comes to $35.41 before shipping ($10 shipping for me to Florida)
Not bad for a complete replacement line. I could have even gone several inches shorter on the line, but I wanted to be safe. The -3 line is pretty much identical in diameter to the stock Greddy line so I feel good about using it, but if you are using anything other than a Greddy kit you might want to use -4.
Total Cats: 6,587
Aw, come on. They're not that hard. Heck, I finally made my first teflon S/S hose connection last week. Finally learned that the secret to a perfect cut is an abrasive metal-cutting blade on a chop saw or table saw.
Zaphod
47
10-26-2018 11:00 PM
Mikel
4
09-28-2015 04:46 PM
