Failed Firmware Upgrade - How Bolloxed Am I?
Old 12-22-2007, 12:51 PM
bbrbob's Avatar
Default Failed Firmware Upgrade - How Bolloxed Am I?
After reading the recent thread on using HiRes code on a MSPNP, I thought I'd try loading it on my 1991 1.6 running a BBR Turbo setup. When I tried to load the code provided by Saboteur it came up with Download Failed - Expected Response "Boot>" but received this "".
I then thought I'd better reload my existing code but the DOS batch file got terminated whilst it was flashing the chip. Now when I try to connect to the MSPNP Megatune shows this message -
Controller Code version does not match signature in MSnS-extra.ini (See audit.log for where the above file was found) - Expected "MSnS-extra format 029q******** (found in .ini file) Received "S - what???Boot>" (from Controller) - Table corruption may occur, this is usually a very serious problem. Terminate Megatune now.
So megatune can't communicate with the PNP and when I turn the ignition on (it wont start anyway) I can't hear the fuel pump priming.
So really my questions are -
How do I get out of this (install new chip?)
How do I upgrade to HiRes once I am fixed (in nice simple intructions)
Am I the only tit that has ever done this?
Time for a sit down and a beer......
Thanks.
Bob.
bbrbob is offline
Old 12-22-2007, 01:00 PM
bryantaylor's Avatar
is your boot jumper still installed?
bryantaylor is offline
Old 12-22-2007, 01:08 PM
he didnt use a boot jumped when he flashed....so it failed.
Old 12-22-2007, 01:24 PM
richyvrlimited's Avatar
He shouldn't need the boot jumper on the PnP as it's the extra code? or have DIY done something different that necessitates it's use?
either way it's not screwd the OP just needs to fit the boot jumper and load the code as per normal.
richyvrlimited is offline
Old 12-22-2007, 04:33 PM
well, it's looking for a boost jumper after he completely erased the existing firmware.
Old 12-27-2007, 10:51 AM
Matt Cramer's Avatar
Total Cats: 67
I'd say try the boot jumper first - often a reflash gone wrong can require using a boot jumper.
Matt Cramer
www.diyautotune.com
Matt Cramer is offline
Old 12-28-2007, 08:40 AM
bbrbob's Avatar
Thank you everyone!! I improvised a boot jumper using a wire, re-flashed and it's now working OK. I really thought I'd fried something there...
Bob.
bbrbob is offline
Frank_and_Beans
Supercharger Discussion
13
09-12-2016 08:17 PM
The Gleas
10-01-2015 09:30 AM
shooterschmidty
8
09-30-2015 10:28 PM
brandonbkd
09-28-2015 11:52 PM
Quick Reply: Failed Firmware Upgrade - How Bolloxed Am I?
