BEGI Kit Install Pics
Old Dec 26, 2007 | 05:43 PM
sv650_ck's Avatar
Default BEGI Kit Install Pics
For anyone that cares, here's some install pics on my BEGI S1 kit. Has been pretty painless so far. Here's a link to what came in the kit:
https://www.miataturbo.net/forum/showthread.php?t=13769
Got most of the demo work done. This shows the existing coolant routing
Signal source fitting. Didn't realize there was a check valve in the line (should of read the manual more closely) - kind of cut into it but still works.
New coolant fitting for the engine block.
Hose routing from new fitting to lower radiator inlet.
Heater hose gets routed around the intake side of the engine.
New fitting installed in upper radiator hose where the heater hose connects to.
Old Dec 26, 2007 | 06:02 PM
ohhh, take a few of the charge pipe off the turbo for me. I bought a used one and wanna make sure it fits with my radiator hose.
Old Dec 26, 2007 | 06:56 PM
teknikscian's Avatar
nice keep the pics comin!
Old Dec 27, 2007 | 05:06 AM
emmi's Avatar
did u end up ditching the f/ic? or are u keeping it?
Old Dec 27, 2007 | 07:14 AM
sv650_ck's Avatar
I hope to keep it if AEM can help me out.
Old Dec 27, 2007 | 06:02 PM
sv650_ck's Avatar
Stephanie corrected my lower radiator hose install. Should look like this:
OEM power steering cooler gets demoed and replaced with this nice aluminum piece to make room for TBD intercooler.
Power steering line routing:
Old Dec 27, 2007 | 06:36 PM
kyle242gt's Avatar
Total Cats: -2
Awesome, keep the pics coming.
Old Dec 28, 2007 | 09:20 AM
yeah. I'm particularly interested in pics of the intercooler/radiator area for hot, 103* July track days.
Old Dec 28, 2007 | 06:50 PM
sv650_ck's Avatar
Protective wrap for the heater hoses added.
Oil supply line. Kit came with a T fitting but I had already bought a sandwich plate.
Access to the oil filter is still okay.
Turbo and manifold come with studs and fittings installed.
Oil return line and one of the water lines gets installed while they're still accessible.
Two piece down pipe.
Had to grind a small amount of weld off for a flush fit to the turbo.
Old Dec 28, 2007 | 06:57 PM
musanovic's Avatar
wow pretty nice. I like. Love that Power steering cooler. How much for that thing if you don't mind me asking? good luck with the build. Btw the FMIC is not too hard to install i have a decent size on my car and with help of whaaamx5 it was a joke. Easiest thing ever.
Old Dec 28, 2007 | 07:06 PM
sv650_ck's Avatar
Got to save up for a FMIC, hd clutch and larger injectors. Pricing on everthing that I've bought is in this thread, towards the bottom of the first page.
Old Dec 28, 2007 | 07:36 PM
kyle242gt's Avatar
Total Cats: -2
Beautiful stuff, great shots too! This thread makes me want to write BEGi a blank check.
Old Dec 30, 2007 | 10:46 AM
sv650_ck's Avatar
Had cut a little sheet metal (blue area) to get the turbo in. Other option would have been to remove the bottom front stud off the exhaust manifold.
According to the manual, fastners have to be tightened in a specific manner to keep the converter from touching the bottom of the car. Turbo to DP, DP to CAT, Turbo to Manifold.
Plenty of clearance for the CAT, but the smaller tube on DP is touching the under body and the lower tube has minimal clearance between the frame.
Old Dec 30, 2007 | 06:43 PM
spike's Avatar
I gotta ask,what is the point in having a power steering cooler?
Old Dec 30, 2007 | 08:04 PM
cardriverx's Avatar
So the power steering fluid doesent over heat?
Old Dec 30, 2007 | 08:33 PM
spike's Avatar
^ did M1 miatas even come with one from the factory,and would it benefit from one,or is this stricly a M2 mod.
Old Dec 30, 2007 | 08:37 PM
miatamania's Avatar
take a hammer to that body
Old Dec 30, 2007 | 08:49 PM
Pretty sure all PS cars have a PS cooler. The fluid gets hot and will cavitate or boil out if it gets way to hot. This is obviously a problem. The PS cooler is a coil of tubing in the mouth of the car. Maybe NA's don't have one, i don't see how that is possible though.
Old Dec 31, 2007 | 02:10 AM
j_man's Avatar
NA had it until '95 but Mazda went cheap and didn't put it in the '96-'97 cars. In '99 Mazda returned it back but only in the manual gearbox cars - the slushbox ones lack it (I guess the folks at Mazda decided noone would buy a slush box to drive it at the track)
Old Dec 31, 2007 | 10:16 AM
Stephanie Turner's Avatar
Total Cats: -100
The stock cooler in the NB models is in the way of the intercooler. So we replace it to make installation easier. We could include spacers for it, but then you have to look at the cooler and the intercooler. Not very pretty.
As for the downpipe hitting the tranny, shoot me an e-mail - I have a part I can send you. There is a motor mount spacer that will help with clearances.
Stephanie
