Small Software Project -> Logging!
Old 02-13-2008, 05:10 PM
AbeFM's Avatar
Default Small Software Project -> Logging!
cjernigan, I have been boosting, gently. I haven't yet installed EBC, and I've got my MBC bypassed, so I'm running on base can pressure- about 5 to 6 PSI. I haven't really romped on it much since the VE table still needs a good dyno session, but I have been boosting mildly. I'm really impressed by how totally seamless the transition into boost is with this setup relative to the EMU- no sudden jump in AFR, just a nice, smooth curve.
This brings in a nice side project I want to do, when I find someone who wants to do it for me. :-) I want to make a script for concatenating log files. MegaLogViewer has a nice autotune function (if you keep an eye on it), and I have log files at probably 6 different boost levels. I could do all my tuning in one go, averaged over a huge range of settings and with hours of log-time, but I want a way to string them together.
Any ideas? They are just .xls, and you have to do a small amount of tweaking (remove/renumber the manual mark/resets, and maybe the timestamps need a touch up.
AbeFM is offline
Old 02-14-2008, 08:00 AM
richard_ha's Avatar
I've also been thinking about this. Essentially just creating lost of logs about 20 minutes long and being able to add them all together and create one megalog (think i've just come up with the program name) of hours worth of data to do a VE analysis with.
richard_ha is offline
Old 02-14-2008, 08:03 AM
richard_ha's Avatar
All you have to do is open one file, and paste another on the end (not including the headers) it works fine.
Old 02-14-2008, 08:34 AM
richyvrlimited's Avatar
It's a nice idea, but I did a datalog of 30ish miles, (just from home to work) and then used the analysis on my desktopp PC (2.5Ghz dual core 2GB ram etc etc.) and it properly chugged along, took about 20 minutes to analyse the file.
There is a benefit to longer files, but only to a point.
richyvrlimited is offline
Old 02-14-2008, 08:57 AM
richard_ha's Avatar
Really? My laptop did a 45 minute log in about 10 seconds
Old 02-14-2008, 09:53 AM
10 seconds? did you log anything in that 45 min period
Old 02-14-2008, 10:35 AM
richard_ha's Avatar
yeh, 45 minutes worth of driving!
You might need to update your java installation or something?
Old 02-14-2008, 10:58 AM
Atlanta93LE's Avatar
Take a look at MegaTweak (I believe it is actually MegaTweak3000). It is essentially a standalone VE Analyzer that takes many logs as the input.
Atlanta93LE is offline
Old 02-14-2008, 11:26 AM
Total Cats: 4,076
Old 02-14-2008, 11:32 AM
wtf?
I'm well aware of it's inbuilt filtering, but the filtereing doesn't really have anything to do with the thread....
Old 02-14-2008, 11:35 AM
Total Cats: 6,587
Surely even the MS-II dweebs can use Autotune?
Joe Perez is offline
Old 02-14-2008, 12:37 PM
AbeFM's Avatar
Joe, we can't just be expected to go clicking things at random..... I was a big autotune fan, then I just somehow never used it. :-) The point is I have a lot of logs already in exsistance I want to use - covering a lot of ranges. Also, have you seen the weird things auto-tune/auto-analyze will do sometimes?
Nonetheless, there's a few reasons to do this: Also, it makes a huge log file so I can look for certain 'events of interest'. So in an ideal world, it would bring the marks and resets with it.
Does it? It didn't for me! There really isn't much header, but skipping that line, it seems to get mad about the RESETs and MARKs not being sequential.
Oh, I'm sure there's a point to longer files, more averaging. I hate to see only 15% of my cells change, also.
And, yeah, my logs, even hour long drives, take a few seconds to run (on a decent quad core machine), but even on work's crappy laptop it still is a matter of a couple tens of seconds for a typical 20 minute log at most. You need to figure out why yours is running slow, something is wrong.
Oh! There's an answer I like. I couldn't find it on ten-seconds-at-google, but I'll keep digging.
Interesting, DIY says it's "outdated, use MLV now"
AbeFM is offline
Old 02-14-2008, 01:01 PM
Total Cats: 6,587
I just stitched two logs together in Excel and MegaLog digested the result with no complaints.
First, I made sure that there was only one header, by copying and pasting only row 3 and down from each subsequent log onto the end of the first log.
Next, I searched for "mark" and deleted all rows containing one.
Last, I found the point at which each new log segment began (I'd previously highlighted the last line in each segment before pasting the next segment in) and adjusted the time (column 1) for each log segment by adding the stated time to a constant which was the last stated time of the previous log. (I didn't touch the 0-255 counter, only the realtime.)
Then I saved the result as text (tab delimited), changed the extension to .xls, and loaded it into MLV.
Old 02-14-2008, 05:10 PM
richard_ha's Avatar
What version of MLV are you using? As i said it worked fine for me just adding on on the end (minus the first two lin)
Old 02-14-2008, 08:02 PM
AbeFM's Avatar
I asked the guy who writes MLV and he said he gets the request a lot. Mine's the newest, generally, since it autoupdates. I'd like to make a script/macro to do it, though my excel skills aren't all that. Ideally, re-enumerating the marks, but that's likely too much to ask for. It's just kinda a chore to do it by hand!
-Abe.
AbeFM is offline
Old 02-14-2008, 08:24 PM
richard_ha's Avatar
Try opening this in MLV.
File Type: zip
Old 02-14-2008, 10:18 PM
elesjuan's Avatar
Total Cats: 43
I did about 7 hours of data logging when I first got mine going, all in one shot. My logging/tuning computer is a Sony Notebook, Pentium 3 1.0ghz, 328mb ram (piece of **** sonys...) running XP Pro. That took me all of maybe 14 - 17 minutes to process. Dunno why yours takes so long.
elesjuan is offline
Old 02-14-2008, 10:36 PM
Total Cats: 6,587
Say what you will, but the Vaio TX and TZ-class machines are just about the awesomest notebook since the Tandy 100. Sure they ain't the fastest thing in the universe, but they're smaller than hustler's dick and yet they still have built-in optical drives.
Old 02-14-2008, 10:57 PM
grippgoat's Avatar
I should be able to whip this up in C# super fast.
Starting.... NOW!
EDIT: what do marks look like in the log?
-Mike
grippgoat is offline
Old 02-14-2008, 11:31 PM
grippgoat's Avatar
Takes a list of log files on the command line. Strips out marks. Adds an offset to the timestamp on later logs. Dumps the output to the console, so you have to pipe it into a new file.
Requires .NET 2.0 Runtime
Zip:
MegaLogCombine.zip
Code:
Code:
using System;
using System.Collections.Generic;
using System.Text;
using System.IO;
namespace MegaLogCombine
	class Program
		static void Main( string[] args )
			double timeStampOffset = 0;
			double currentTimeStamp = 0;
			int iLog = 0;
			int fieldCount = 0;
			foreach ( string arg in args )
				string[] lines = File.ReadAllLines( arg, Encoding.ASCII );
				for ( int iLine = 0; iLine < lines.Length; ++iLine )
					string line = lines[ iLine ];
					// strip out the first two lines of all logs besides the first
					if ( iLine < 2 )
						if ( iLog == 0 )
							Console.WriteLine( line );
						continue;
					// Don't want mark lines
					if ( line.Contains( "\"MARK" ) )
						continue;
					string[] fields = line.Split('\t');
					// don't do empty lines
					if ( fields == null || fields.Length < 1 )
						continue;
					if ( fieldCount == 0 )
						fieldCount = fields.Length;
					else if ( fieldCount != fields.Length )
						throw new System.FormatException( String.Format( "Found {0} fields, expected {1} fields, on line: {2}", fieldCount, fields.Length, line ) );
					double timeStamp;
					if ( !double.TryParse( fields[0], out timeStamp ) )
						throw new System.FormatException( String.Format( "Failed to parse timestamp from line {0}", line ) );
					currentTimeStamp = timeStamp + timeStampOffset;
					fields[ 0 ] = currentTimeStamp.ToString();
					StringBuilder builder = new StringBuilder();
					for ( int i = 0; i < fields.Length; ++i )
						if ( i > 0 )
							builder.Append( '\t' );
						builder.Append( fields[i] );
					Console.WriteLine( builder.ToString() );
				timeStampOffset = currentTimeStamp;
				++iLog;
-Mike
Quick Reply: Small Software Project -> Logging!
