MSPNP HighRes firmware images
Old 03-05-2008, 02:45 AM
timk's Avatar
Total Cats: 37
Default MSPNP HighRes firmware images
For those interested in upgrading their MSPNP to HighRes but don't want to have to mess with EasyTherm, I have created firmware images that have been modified to suit the MSPNP. The page covers 90-95 and includes firmware images for setups with and without the AFM/MAF:
HighRes firmware images for MSPNP
It is hosted on another site where I can easily make changes if needed for newer versions. On here I can't seem to edit my posts after the thread gets replies.
Hope this helps someone!
Cheers
timk is offline
Old 03-05-2008, 07:08 AM
richard_ha's Avatar
Cool, just did this. You might want to add the capacitor mod as mine had the tach drop out without it.
richard_ha is offline
Old 03-05-2008, 09:03 AM
it would have been really thoughtful to include the therm files so the temperatures are outputted correct on your tuning laptop.....because one still has to "mess" with easytherm to both create them and/or upload the firmware.
Old 03-05-2008, 05:15 PM
timk's Avatar
Total Cats: 37
It would have been really thoughtful if you had read the Flashing a MegaSquirt PNP to the HighRes firmware which is linked at the bottom of the page. If you follow this, you will re-use all your old project files (including the .inc files and download-firmware.bat) which are identical to the ones packaged with HighRes.
I thought this would be advantageous so people could still follow the documented way to reflash their firmware. You won't need EasyTherm, at all.
Cheers
timk is offline
Old 03-05-2008, 06:47 PM
ah gotcha, missed the whole PNP thing
Old 03-05-2008, 08:27 PM
Atlanta93LE's Avatar
I'll definitely try this out when I get a moment with the car. Thanks!
Atlanta93LE is offline
Old 03-15-2008, 05:27 PM
smifta's Avatar
shouldn't these zips have the msns-extra.ini file in (not the megatune.ini file)
Very useful none-the-less !!!
smifta is offline
Old 03-16-2008, 02:00 AM
timk's Avatar
Total Cats: 37
Absolutely, thanks for the heads up! I will fix this in the next few days.
Cheers
timk is offline
Old 04-01-2008, 03:51 AM
timk's Avatar
Total Cats: 37
Thanks again smifta, I've now fixed all the downloads.
timk is offline
Old 04-12-2008, 06:05 PM
Thanks for the firmware images, worked great. One thing: the BoostDC gauge went missing in MegaTune with the new files. I followed this thread to fix it. You might want to make the change in the downloadable files. Thanks!
Old 04-12-2008, 09:28 PM
The_Pipefather's Avatar
Total Cats: 14
I have a regular v3 board with Braineack's mods and I'm running 029y4 successfully right now. Any hardware changes that i should be doing to use the HR10g code?
The_Pipefather is offline
Old 04-12-2008, 09:39 PM
No mods needed to run 10G, just reflash.
Old 04-12-2008, 10:14 PM
Ben, did you add the cap filter? If not, any issues? Thx
Old 04-12-2008, 10:20 PM
Nope. I had one mild misfire in boost, which I think was spark blowing out, but I'll be adding the cap after further testing. I may run over to DIY and just have them do it for the peace of mind.
Old 04-12-2008, 11:25 PM
Sweet. I just spent the last 45 minutes hand copying everything over to a hi rez msq. Did everything by hand including the ve and spark tables. Taking no chances.
Old 04-12-2008, 11:29 PM
You didn't hear? The HR10g code cured the issue that made us hand copy
I simply reflashed, reloaded my original MSQ, tuned, and BAM.
Old 04-12-2008, 11:32 PM
No, and thanks for telling me now. Dick.
Here's the sad part. I did all that on my desktop. Now I have to figure out how to get the folder on this old laptop. Guess it's time to run the windows networking wizard
Old 04-12-2008, 11:48 PM
I guess this thread would have helped
Old 04-13-2008, 12:09 AM
complete and total failure
car barely idles, if that. stalls with any throttle RPM does not show in megatune.
Old 04-13-2008, 12:11 AM
91NApeewee's Avatar
is megatune configured correctly to see the highres controller?
91NApeewee is offline
Quick Reply: MSPNP HighRes firmware images
