workin on the car so i took some shots
Im in the process of my reroute and I got a little camera crazy.... so here you go..
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
while im doing this i figured why not drop the PS out of the car...
exhaust
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
exhaust
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Alright guys Im still in the process of doing my re-route.. I am trying to make a re-route where you can re-use all stock parts... so far the only non stock parts are a spacer i made and a plate. and a turbo tim thermostat.. looks like i need one piece of flex hose to be done!!! Utilizing all stock parts!!
GAB is the only manufacturer to make a shock that adjusts for both rebound and jounce. As well, their 8 way adjustables have a range that is just a tad stiffer than stock to making you wonder if the shocks are actually moving at all and aren't just red chucks of aluminum stuffed into the cavity. The adjustment can be done while the car is sitting in a parking lot with no tools at all, the ***** are just infront of the lower pickup points. The major limitations of GAB are two fold, their price (close to $600+ retail) and the lack of availability. (only available though a company called Wingz in the Bay Area (510) California)
This is from back in 95' mind you, so things have changed a bit since then.
Vash-
Ah, I was wondering what you were doing for thermostat. I didn't see a lip machined into the spacer to allow for it... mine is clamped in there atm... i do NOT trust it... (mine).
Maybe external thermostat will be a simpler format for me.
Are there pics/prices for Tims external housing?
Oh.. and how did you align the cams without the back plate? Just marked and clamped in place prior? I fought getting them setup with the black back plate... then just said fug it... and tossed it back on.
Turbo Tim made me a external thermostat housing with a High Flow 180* sensor and I drilled 2 1/8" holes in it to allow for more flow. Im really doing a serious custom job... But it sure looks to be promising!!! I am taking the turbo water return line and routing that through the Heater core! then using that spacer I made to run the heater return line back into the system. And I am machining the thermostat housing to retain the "green" temp sensor.
