depowered my rack
Old 04-11-2008, 03:01 PM
Oscar's Avatar
Total Cats: 120
Default depowered my rack
Finally got around depowering my steering rack. The bottom bolt on the PS pump bracket was a bitch and half to get out, but I managed without any screw ups
I looped the two lines on the rack and it looks decent.
Never thought the hotside could look so clean without the crossover tube and PS pump
pics soon
Oscar is offline
Old 04-11-2008, 03:11 PM
Miotta FTW!
Splitime's Avatar
FM style depower? or just the looped lines?
Splitime is offline
Old 04-11-2008, 03:17 PM
Oscar's Avatar
Total Cats: 120
just looped, couldn't be arsed to take the whole rack out
Oscar is offline
Old 04-11-2008, 04:29 PM
Dark Wanderer's Avatar
I read the tutorial on the FM website, but is there any advantage to make the depower process like they do it instead of just looping?
Dark Wanderer is offline
Old 04-11-2008, 04:32 PM
JDMAflac's Avatar
looking forward to pictures. Currently mine is drained with no belt.
JDMAflac is offline
Old 04-11-2008, 05:14 PM
Oscar's Avatar
Total Cats: 120
so for I just looped the lines in the red circles, didn't have time for the blue ones as it was getting dark. do these need to be done too or can I leave them like that? they seem more of a PITA than the ones I already did.
Oscar is offline
Old 04-11-2008, 05:33 PM
downtavern's Avatar
Looping the blue lines is very important because if you don't preasure will build on either side of the middle seal and adversely affect effort and feel. Someone correct me if I'm wrong.
Nate
downtavern is offline
Old 04-12-2008, 07:50 AM
Oscar's Avatar
Total Cats: 120
almost with the 'blue' lines, will take pics afterwards
Oscar is offline
Old 04-12-2008, 09:00 AM
alden77's Avatar
Guys
I did mine the FM way after driving it looped for a while. The FM way removes the piston and PS fluid from the rack and this makes it easier to turn the wheels because the friction of the piston is missing. It took a few hours and I got PS removal plugs from a spec miata company on the net somewhere. I'm glad I did it that way. I also got the pulley assembly for a non PS miata from a dealer.
Best Always
Alden
alden77 is offline
Old 04-12-2008, 12:14 PM
Oscar's Avatar
Total Cats: 120
finished looping the rest of the lines, belly pan is back in it's place too. getting that cooler line for the PS fluid in the bumper out was a bitch too, but got it done in the end
pics:
Oscar is offline
Old 04-12-2008, 12:17 PM
So... How do you like it.
Old 04-12-2008, 12:24 PM
Oscar's Avatar
Total Cats: 120
I wouldn't know car's not running yet, still need to do LC-1, IAT and knocksense.
Oscar is offline
Old 04-12-2008, 12:44 PM
brgracer's Avatar
FWIW, both my current miatas are depowered. The lines were just drained and looped on one, and the other was depowered the FM way. Drained and looped is livable, and I was very happy with it until I drove the one with the "properly" depowered rack. IMHO, after comparing the two back to back, I think the extra effort to remove the inner seals makes a significant enough difference to be worth it.
brgracer is offline
Old 04-13-2008, 02:20 PM
boostinboy's Avatar
sorry if i seal your thread. but whats the reason people depower there miatas?
wouldnt it make the car harder to steer?
boostinboy is offline
Old 04-13-2008, 02:21 PM
That's the whole idea. The Miata's PS is overboosted, in the opinion of many here, so removing the PS gives the steering some weight and tons more feedback.
kotomile is offline
Old 04-13-2008, 02:30 PM
johndoe's Avatar
so you can actually tell how much grip the front wheels have
johndoe is offline
Old 04-13-2008, 02:47 PM
When you depower the rack, do you get out the pump and the belt of the car? In that case, this make the routing for IC piping easier?
Mach929's Avatar
i have mine lines cut and half-assed looped. because when i did it couldn't find the right hoses. i'm not sure what difference it will make because it still feels exactly the same as before i cut the metal lines. but i will say you can feel EVERYTHING now, i can feel the car slipping about 3mm on the tiny amount of gravel as i turn into my neighborhood.
Mach929 is offline
Old 04-13-2008, 03:33 PM
Oscar's Avatar
Total Cats: 120
yes, should be. hotside looks a lot cleaner without pump and belt.
I cut my lines too, used some rubber hose I had from my scooter and looped them, ghetto as hell, but if it works, who cares
can't wait to feel the difference in feedback, curious what I'll notice on track. Didn't feel the front wheels lose grip until I noticed I was 2 meters of the ideal line
Oscar is offline
Old 04-13-2008, 08:10 PM
boostinboy's Avatar
do you have to pull the engine to loop the lines?
Quick Reply: depowered my rack
