Brake Rotor stuck really bad
Total Cats: 14
Ok here's the story. I changed rotors, pads and hardware at 3 corners with zero issues.
On the 4th corner, the damn rotor is frozen to the hub. I tried bolt after bolt in the center hole thats supposed to force the rotor out, but all of them strip after they contact the hub. I dont know if I'm using the right sized bolt? Its a M8 x 1.25 mm (I dont have a spare tiedown bolt that people normally use here).
Then I tried wedging the jack between a piece of wood supported with the chassis, and the rotor. No go.
Went to autozone, rented a 5 ton 3-jaw puller and used that on the outer surface of the rotor. Damn thing didnt budge a hair, so I heated the rotor with a Bernzomatic, and I ended up separating the rotor surface from the boss that holds it in place. Kinda like this (THIS IS NOT MINE):
http://groups.msn.com/SVTCobraR/brem...oto&PhotoID=24
Now the rest of the rotor is still behind the rotor boss and I don't know how to get the boss out.
Help me out with suggestions, guys???
Find someone with an air hammer or see if any hardware stores rent them, I run into that problem often at work, and on the few severe cases like yours, the air hammer gets it off fast. Or just take a flat chisel and try to get between the hat and the hub if possible. Like others said PB blast the hell out of it. It will come..
Total Cats: 14
Air tools or tools of any kind that make noise are out because I live in an apartment. But a hammer is ok. I will try all of these in turn till I get it out. I already gouged the driveshaft face pretty bad with the puller bolt.
Total Cats: 17
Not trying to be condescending here, just clarifying, but by "hammer" or "BFH" we don't mean your typical framing or woodworking hammer. Not heavy enough. You need about a 3-5 lb mallet. Spray the rotor-hub interface liberally with PB Blaster or the like and let that stuff work overnight, and it should pop off with a couple of hits.
