Intake backfire before cranking.
Old 08-13-2008, 01:53 PM
wes65's Avatar
Default Intake backfire before cranking.
I have the mspnp9495 and whenever i turn the key to the on position before a cold or warm (not hot) start, there is an intake backfire. It seems to be exactly 2 seconds after the key is turned to the on position and will occur before cranking. If i don't allow 2 seconds between key on and cranking, it will usually backfire while cranking. I have recently changed from 460cc injectors to 550cc injectors and the problem occurred with both sets of injectors. So i know it's not the injectors Any idea what may be causing this?
Thanks in advance,
Wes Wingham
I can attach my msq later when i get home.
wes65 is offline
Old 08-13-2008, 02:13 PM
Saml01's Avatar
Go into the cranking settings and look at the prime settings. Disable it.
Saml01 is offline
Old 08-13-2008, 02:25 PM
wes65's Avatar
I will try that when i get home. Now, when it says priming pulse, is it talking about fuel or spark?
wes65 is offline
Old 08-13-2008, 02:26 PM
search ------ search.
10-03-2015 11:04 AM
Aroundcorner
10-01-2015 03:20 PM
Trent
10-01-2015 12:15 PM
viriiguy
General Miata Chat
09-28-2015 07:39 PM
Quick Reply: Intake backfire before cranking.
