news
Old 07-28-2007, 08:52 PM
Dow.tom's Avatar
Default news
Any news on them the MS comes PnP for 94-97? I want it! heh
Dow.tom is offline
Old 07-28-2007, 10:29 PM
FoundSoul's Avatar
I guess I can spill the beans now... and you beta testers can come out of hiding if you'd like
We've been beta testing on a few cars for a few weeks now-- our car has been running the system for 3 months in one form or another, and we've got one N/A car, one turbo car, and one SC car running it as well, for various amounts of time. The turbo car has been running it the longest second to my own car-- he's got a couple thousand miles on it by now I believe.
All of the guys frequent this board so I'll let them comment on it if they want--
System is for the 94 and 95 cars, things change a good bit in 96 so we'll be there next.
Features are pretty much the same as the MM9093 unit, but with the MM9495 we're making the 4 Bar MAP Sensor and Barometric correction standard.
You guys are getting the inside scoop here, there's nothing up on the MegaSquirtPNP.com site just yet. I'm finalizing the manual, updating the software CD, finalizing the base map, and getting it ready to start shipping. Units are in production though. We're a week or so away from the release date.
Jerry a.k.a. 'FoundSoul'
DIYAutoTune.com
'95 Miata n/a
A few other cars....
FoundSoul is offline
Old 07-28-2007, 10:31 PM
reddroptop's Avatar
Jerry, will you be making the map public?
My car is basically stock with a cone filter. No MAF. I think your stock map's (spark and fuel) would be a 1000% improvement over what I have cobbled together.
I will be running toyota COP's, but that shouldn't effect the maps much.
If you could make them public it would be VERY appreciated, when they are ready.
Thanks.
reddroptop is offline
Old 07-28-2007, 10:37 PM
FoundSoul's Avatar
Thanks.
Have we ever let you down before?
Yeah we'll end up posting the map on the MegaSquirtPNP site, you guys that go the DIY route can benefit a bit as well hopefully though there may be minor differences, it should still be really helpful though.
We picked up 12whp and 7wtq over the stock ECU after deleting the MAF. A bit less with the MAF still installed. (think it was 8whp and 4wtq IIRC)
DIYAutoTune.com
'95 Miata n/a
Old 07-28-2007, 10:47 PM
Dow.tom's Avatar
alright, excellent, any news on pricing? And set amount of units to be sold before backorder?
Dow.tom is offline
Old 07-29-2007, 12:01 AM
reddroptop's Avatar
Is that on the 1.8 or the 1.6?
And THANK YOU!
I know who my next order will be with if I need anything else megasquirt related. Maybe a megaview.
Old 07-29-2007, 12:37 AM
Dow.tom's Avatar
is it best to install MS on a stock engine, get it running than install the turbo and tune from there? Also will it run on a stock engine?
Dow.tom is offline
Old 07-29-2007, 01:01 AM
sotaku's Avatar
that's excellent news, great work!
can't wait to see the 96... (sure I could build one, but what you guys have done makes me wonder if I'd rather just skip to PnP in all of its slickness)
sotaku is offline
Old 07-29-2007, 01:37 AM
wildfire0310's Avatar
Everyone is going to say yes. The Pnp help alot for been able to install after a turbo. It makes more sense to install it per turbo and learn the system first then run it turbo. Again this also came from having to make sure everything worked right and your fuel and spark maps where working correctly. Jerry has solved alot of those problem with the Pnp.
Jerry that is great news about coming out with the 94-95 already.
When you start doing the 99-00 model, talk to Thomas about a tester,a local with a m45 intercoolered.
Good luck with everything
wildfire0310 is offline
Old 07-29-2007, 08:48 AM
Dow.tom's Avatar
With the Ms pnP do i still need a O2 clamp? Or does having complete control over fuel resolve that issue?
Dow.tom is offline
Old 07-29-2007, 08:56 AM
Atlanta93LE's Avatar
No O2 clamp needed with MS
Atlanta93LE is offline
Old 07-29-2007, 10:09 AM
FoundSoul's Avatar
Pricing will be $725, the mild increase is in the 4 bar and baro correction features.
The power numbers I quoted were on our 95 M-series 1.8l car. Back to back on the same day, same dyno.
I would recommend making a change at a time... so if your plan is to go turbo with massive injectors and the MSPNP controlling it all
1) Install the MSPNP, get familiar with the tuning interface
2) Install the bigger injectors, you're still getting used to tuning your MSPNP at this point probably, including what it takes to upgrade your injectors (which is easy BTW)
3) Go Turbo!
In between each step you'd make sure all is well before moving on to the next step-- if you do run into trouble it's MUCH easy to identify the source of a problem if you control how many changes you make at a time... And it's nice to be familiar with your EMS before you dive into tuning a turbo car with it.
DIYAutoTune.com
'95 Miata n/a
Old 07-29-2007, 10:24 AM
Dow.tom's Avatar
okay thank you, i will be ordering this! woohoo!
Dow.tom is offline
Old 07-29-2007, 10:29 AM
Awsome job Jerry MS is fast becoming a miata sensation
Old 07-29-2007, 10:32 AM
Dow.tom's Avatar
hey magna... i guess my turbo may be coming faster than i thought. With this it will cut down my install time by so much. I'll install it stock, and than go from there. When can i come down and visit haha.
Dow.tom is offline
Old 07-29-2007, 10:42 AM
FWIW, I rode in a forum member's car immediately after installing the 94-95, and with NO tuning done at all, I was very impressed at how quickly the car started up and how well the car drove.
Old 07-29-2007, 10:51 AM
Dow.tom's Avatar
when is this going to be available? How'd ytour friend get it? was it a built one not PnP?
Dow.tom is offline
Old 07-29-2007, 11:21 AM
It was the PNP. I happened to show up at DIY-Autotune as they were installing it. You know, all of like 10 minutes that it literally takes to install it. It was a forum member's car, but it's up to him if he wants to remain anonomous or not.
Old 07-29-2007, 11:35 AM
Dow.tom's Avatar
ah okay, so he was a beta tester? The rest of the world needs to wait for another week or so?
Dow.tom is offline
Old 07-29-2007, 12:36 PM
FoundSoul's Avatar
Ben dropped by the shop when we were putting it on one of the beta cars-- the N/A one.... as he mentioned it fired up first try, we set base timing, and they went for a drive. When they got back we made a tweak to the idle control settings to dial it in for his TPS and I believe it's been working very well for him since then.
He's planning to go turbo I believe.
DIYAutoTune.com
'95 Miata n/a
Quick Reply: news
