Compression Test Numbers
Old 04-27-2005, 03:08 PM
White Roadster's Avatar
Default Compression Test Numbers
From the Factory Mazda Miata Manual:
Compression:
192psi @ 300 rpms (new)
Minimum:
135psi @ 300 rpms
Differential limit between cylinders:
28psi
White Roadster is offline
Old 09-09-2007, 06:33 AM
akaryrye's Avatar
so what if its higher? I got 210 on all cylinders after a rebuild a couple thousand miles after first start. the test was done warmed up, all plugs out, Fuel injectors disconnected. I need to retest now that ive got about 5-6k on the motor.
akaryrye is offline
Quinn
Cars for sale/trade
6
10-23-2016 07:58 AM
01-03-2016 07:18 PM
zephyrusaurai
09-28-2015 10:59 PM
Quick Reply: Compression Test Numbers
