old SAFC on 1.6
Old 06-18-2006, 01:03 AM
Kirby's Avatar
Default old SAFC on 1.6
So ive been doing some reasearch on what i want to do with fuel delivery on my 1.6. I decided to ditch my FMU for supra 310cc Greentop injectors and run a SAFC 1st gen (**** type) for tuning. I read that 1.6's have a throttle switch instead of a TPS on 1.8's. So would that be a problem considering the SAFC dose not tune for partial throttle conditions.
Thanks!
Kirby is offline
Old 06-18-2006, 09:01 AM
getsidewaysd1's Avatar
I have know idea. Most people with miatas just run emanage.
getsidewaysd1 is offline
Old 06-19-2006, 10:07 PM
ITs going to be hell. I installed one on a vw once, and it was just a waste. emanage is so easy, its the best choice.
Old 06-20-2006, 12:51 PM
Jefe's Avatar
If you meean the one with real *****, it only really can tune for WOT..BTDT, it worked well(pig rich) w/ 330's AND a BEGI FMU though...
So keep the FMU and you might get some reasonable results.
What are you using for timing?
Jefe is offline
Old 06-20-2006, 06:03 PM
Kirby's Avatar
Im using the Jackson racing ignition controller. Will the 2nd Gen SAFC with the blue screen and buttons tune for partial throttle conditons?
Kirby is offline
Old 06-21-2006, 02:04 PM
Jefe's Avatar
Sort of, you'll need larger injectors- the SAFC is better at removing fuel than adding it. You'll also need a map sensor, and some patience w/ the funny software. I might be able to dig up some old links if you are serious, but the Emanage Blue is 5X the unit for a fraction more...
IIRC saturn turbo(.net?) has a write up on using the safc II w/ a map sensor, and an old DSM site.
Jefe is offline
Old 06-21-2006, 02:06 PM
Jefe's Avatar
http://www.2gnt.com/www/corbin/foolafc.html
http://www.turbosaturns.net/articles/SAFC%20install.htm
Jefe is offline
Frank_and_Beans
Supercharger Discussion
13
09-12-2016 08:17 PM
Trent
10-01-2015 12:15 PM
Dustin
09-23-2015 10:34 PM
concealer404
8
09-17-2015 12:04 PM
Quick Reply: old SAFC on 1.6
