Coolant reroute progress
Old 07-19-2006, 09:32 AM
Sirnixalot's Avatar
Total Cats: 17
Default Coolant reroute progress
I modified the 1.8's thermostat outlet to point more or less in the right direction. I didn't have access to a competant welder so i jb welded the **** out of it, i dont have any really good pix of the outlet itself but here is what i have so far.
I'm using 1.25" aluminum tubing i got from the hardware store and some random hoses. I plan on running the pipe along the side of the intake manifold and using the holes for the intake manifold support bracket to secure the pipe to.
View from the top of the head
View from the passenger side.
Sirnixalot is offline
Old 07-19-2006, 09:42 AM
AFM Crusader
olderguy's Avatar
Total Cats: 336
I don't know that I would trust JB Weld it that situation
olderguy is offline
Old 07-19-2006, 11:14 AM
Sirnixalot's Avatar
Total Cats: 17
im not sure about it either, i have a spare outlet that i can try to get welded. Unfortunately no where on island has a 1.6 thermo-outlet
Old 07-19-2006, 11:49 AM
I'd trust it if you used it has a sealer and thread locker on an elbow that was screwed in to the housing, but not as you have it now. It won't hold with the fluid, heat, contraction/expansion and the hose yanking on it. You should be able to find another fitting that will work back there, and then you can add a brass barb to the housing for the heater core feed. That's what I did on the FE3... but I think what I'm using is an original fwd FE3 t-stat coolant fitting. Maybe something from a protege or escort gt would work? - rob
Old 07-19-2006, 12:17 PM
Sirnixalot's Avatar
Total Cats: 17
i might have to end up getting an outlet made, a 1.6 outlet is only like $20 new at the dealer in the states but shipping & duty will probably negate the cost.
Old 07-19-2006, 12:55 PM
AFM Crusader
olderguy's Avatar
Total Cats: 336
Any junk yards on the island? Many T/stat bodies are similiar in bolt pattern, and of coure the T/stat mounting is universal.
olderguy is offline
Old 07-19-2006, 01:05 PM
Sirnixalot's Avatar
Total Cats: 17
there are a few body shop places that keep some cars but i havent spotted any miata's.
I imagine it would be simple. just get some 1/4" aluminum plate, 2" (or so thick walled piping and then some 1 1/4" pipe.
pop the bolt and thermo holes in the plate, weld 1.5" of the 2" pipe to the plate, cap it, pop a 1.25" hole in the side for the 2" of 1.25" pipe.
I usually over simplify **** in my mind but that seems fairly straight forward?
slomiata
10-07-2015 01:11 PM
FrankB
10-02-2015 09:00 PM
shooterschmidty
8
09-30-2015 10:28 PM
drumman83
09-25-2015 07:03 PM
Quick Reply: Coolant reroute progress
