Ghettocharger Revision 1.00
Old 12-07-2006, 12:55 PM
Markp's Avatar
Default Ghettocharger Revision 1.00
Here is the dyno chart... Feel free to discuss. Numbers are uncorrected. Corrected numbers would have been around 310 RWHP and 277 ft/lbs of torque. I had another run with 264 ft/lbs and 296 RWHP, this was the backup run with 259 Torque 296 RWHP.
Mark
Markp is offline
Old 12-07-2006, 01:12 PM
F20turbo's Avatar
Looks good mark, I just saw the chart on miataforum. That kind of power is what spins the first 3 gears with ease. However, like me you see massive torque dropoff on the topend. I believe that when we move to the BEGI Intake Manifold that we will carry torque deeper into the rpms. From the looks of your chart you spool just a tad slower than I do, maybe 500rpms or so. The lag isnt nearly as bad as I had imagined it would be. When you get a new exhaust manifold I bet power will carry out after 7000rpm a LOT better, not to mention the new intake manifold as well. If I was you though I would be shifting at 7200 on your setup since revving it out wouldnt be worth it...still must be nice to carry it out to 8500 though
F20turbo is offline
Old 12-07-2006, 01:29 PM
Efini~FC3S's Avatar
Total Cats: 98
It looks a little lean (almost 13 at ~5400 rpm) near peak torque. If it's a butt sniffer it should be good but if it was me I would want it to be a little richer around peak torque.
Something like that *arrow down*
Efini~FC3S is offline
Old 12-07-2006, 01:35 PM
is that with the new manifold?
Old 12-07-2006, 05:10 PM
Markp's Avatar
No, that's the old manifold.
Mark
Markp is offline
Old 12-07-2006, 06:28 PM
TurboTim's Avatar
Total Cats: 399
Nice.
TurboTim is offline
Old 12-07-2006, 06:40 PM
Mach929's Avatar
doesn't look like going past 7000rpm is doing much for you at this point(maybe the manifold?). The intake manfold might help but i'm guessing cams are what you really need since it looks like you're making more power at 5Krpm than you are at 8.
Mach929 is offline
Old 12-07-2006, 08:17 PM
(per Efini's post) You're running a minimum 12:8 to 12.0:1 AFR at 15-19psi? Is that the dyno tail pipe sniffer? If so, that shows about a full point leaner- right?
Old 12-08-2006, 12:15 PM
Markp's Avatar
Dyno tail pipe sniffer... so ya, it's probably rich. I didn't datalog it, so I don't know yet.
Mark
Markp is offline
Old 12-14-2006, 01:50 PM
iluvtruenos's Avatar
What is ghettocharged?
iluvtruenos is offline
Old 12-14-2006, 07:05 PM
A way of life :gay:
Old 12-14-2006, 07:17 PM
A diy turbo setup built around a chinacharger.
Old 03-27-2007, 11:05 PM
smallblockman69's Avatar
Very Nice
smallblockman69 is offline
Old 03-28-2007, 12:21 AM
turbopezz's Avatar
ah,now that this is backup.
the phrase the nimbers are uncorrected what does that mean.
its ran on a different type of dyno,or above sea level.
turbopezz is offline
Old 03-28-2007, 08:45 AM
no it gave raw dyno numbers with no altitude and or temp compensation. for STP
Old 03-28-2007, 10:47 AM
akaryrye's Avatar
at higher altitudes, cars make less power basically.
akaryrye is offline
Old 03-28-2007, 06:30 PM
turbopezz's Avatar
im at sea level.thats probaly why i never hear of that term.
TheScaryOne
10
06-09-2019 05:29 PM
Joe Perez
Current Events, News, Politics
4
11-30-2012 01:23 PM
Cody Strife
Cars for sale/trade
4
11-27-2011 08:55 PM
Markp
12-05-2006 11:38 AM
Markp
11-21-2006 08:37 AM
Quick Reply: Ghettocharger Revision 1.00
