Nissan T25 Compressor Machining
I finally figured out how to use my Nissan T25 with my current IC and DP setup. The standard method is to use a 3bolt flange adapter and hook everything up that way. With my setup i would have had to modify my IC piping which is powdercoated and not something I wanted to destroy at the moment. So after pondering many ideas such as welding an elbow on the compressor or making a flange and welding an elbow. I realized that the compressor housing though it looks different is the same as a standard housing that allows the use of silicone couplers just with excess alum all around the outlet. So i figured what the heck, why not just machine all of that off, smooth it out and make it work. Well what i ended up with is something that looks almost exactly like the Saab(i think) housing I have. It works perfect and would save anyone the extra $30 or so that the adapter costs. That is of course if they have free machining available or do it themselves.
Compared To This
Compared To This
p.s
.......blow it out ur *** braineck j/k
:gay: always all up on my *** dude:gay: can't a guy have Ideas. oh and Im almost done , all I need are intercooler pipes,couplers,and a custom down And im gravy, Maybe if I get another job I can do it faster my king
time and money , hey If I hit the lotto I'll make my car in one week, but since that **** aint going to happen I do what i can with me crack money.:gay: j/p
You could do it, but it would take ALL DAY it seems. It's just aluminum so you can remove the material easily. You might be better off trying to saw the corner off then smoothing with the dremel.
A Dremel with a carbide bit will go through aluminum like butter. But you're gonna have a couple hundred thousand microsized aluminum splinters EVERYWHERE!!! Get an extension cord and go down to the street... then do the work over a trashcan with a plastic liner. Throw away liner when done. Wear longsleeves and gloves. Throw away shirt when done.
That's a great trick. I have a T25 in my junk bin, and may do the same, but no machine toole here, though my bench grinder, and cheap-*** Harborfreight angle grinder, will make short work of the bulk of it, and then finish up with the Dremel.
For some reason, everyone buys a Dremel and thinks it's the greatest thing since sliced bread. While it does have its' place, if you're playing with cars, get yourself an angle grinder and bench grinder. They're inexpensive, and you'll find lots of uses for them.
C
C
