my xtd is a peice of shit
Old 02-24-2007, 07:11 PM
mxv
mxv's Avatar
Default my xtd is a peice of **** *carnage added*
i hate this ******* thing what a ******* waste. first it has an issue with not disengauging fully. ran out of adjustment on the pedal so i was stuck with having my engagment point about 1/2 inch off the floor. that made me pissed. then throw out bearing started making noise. now on day 7 the throw out bearing is shot probly seized and that means my presure plate forks are probly fucked to hell now and the damn thing only has about 170 miles on it. never got it to even go in gear smooth cause the clutch never disengaged enough. i am running a brand new cmc and slave. looks like i gotta take the tranny BACK out and see wtf.
act ... i didnt want to, but it looks like i may have to let you rape my wallet.
mxv is offline
Old 02-24-2007, 07:51 PM
rotaryjunky's Avatar
Dam, that sucks. Any chance of a refund?
I had a new clutch disintigrate once but it was because my flywheel was warped. I hate to have to do something twice, especially when its not my fault.
rotaryjunky is offline
Old 02-24-2007, 08:14 PM
act pedal position sits on the floor too.
Old 02-24-2007, 08:53 PM
mxv
mxv's Avatar
exactly. ill see if its refund worthy when i get it out.
mxv is offline
Old 02-24-2007, 10:19 PM
spike's Avatar
What's the name of the clutch you are running?
spike is offline
Old 02-24-2007, 10:25 PM
mxv
mxv's Avatar
says on the thread name
mxv is offline
Old 02-24-2007, 10:36 PM
getsidewaysd1's Avatar
Thats weird. I had one in a 220hp miata and it was fine. The engagment was actually high, about and inch or two from the top. As a matter of fact, I drove the hell out of that clutch everyday and never once had a problem.
getsidewaysd1 is offline
Old 02-24-2007, 10:43 PM
Maybe one thing you pay more for is simply consistent quality. I was going to buy one when my clutch gives up. Hmm.
Old 02-24-2007, 11:50 PM
Snowsurfer03's Avatar
Gosh darn brother that sux.
B4 you go let ACT RAPE you try SPEC!
I have a spec stage II and it feels like stock! Also holds my sub-200hp set-up with no issues!
If you need more holding pwr just get a stage 3-4. Goodluck!
Snowsurfer03 is offline
Old 02-25-2007, 02:06 AM
VRTSid's Avatar
yeah I have an xtd and also think its pretty much crap. but my engagement point is also rather high
VRTSid is offline
Old 02-25-2007, 03:45 AM
mxv
mxv's Avatar
yea, mine sucks but i am sure there are guys that have good luck. i read enough good posts about them to give them a try looks like i may have a dud. but once again i wont know till i take it out. if i can still use my disk whats a good presure plate for 220 wtq holding capacity that wont cost much? i have a feeling that the xtd's got eaten up by the seized up throw out bearing.
mxv is offline
Old 02-25-2007, 12:44 PM
Al Hounos's Avatar
yeah, spend almost as much on a spec and risk doing it all over again. get a ******* ACT XT and be done with it. I don't know why so many on this forum try to save a few bucks on one of the most important parts of the car and the biggest bitch to replace.
A good quality $330 277tq clutch is NOT expensive.
Al Hounos is offline
Old 02-25-2007, 12:47 PM
I am very hesitant to buy an ACT because the pedal position is so low, and I don't want to deal with pressing the pedal down into the carpet to get the clutch to disengage for first gear.
Old 02-25-2007, 12:48 PM
Al Hounos's Avatar
it isn't. i've driven cars that engage off the floor and i know that it sucks. my act doesn't.
Old 02-25-2007, 12:53 PM
My buddies car and the TDR car both sit on the floor. I'm going to take a risk either way, one might fail, one might be such a pain in the *** to drive that its not worth the additional $100.
Old 02-25-2007, 01:19 PM
mxv
mxv's Avatar
well the position is so low it never disengages all the way. so when i put in first it goes clanggg. and then 2nd 3rd and 4th and 5th go crunch... just because of this i will not beable to compete at all. everything needs to work. no matter how cheap it is if i pay money for somthing it just has to work... sorry.
is the pressure plate what decides your pedal height? if so... what is one that can hold 220tq and 220 hp and has height that is normal with what ever pedal presure, i could care less.
mxv is offline
Old 02-25-2007, 01:26 PM
My buddy has the same problem on his 1.8. The clutch adjuster is adjusted to the max level, and you have to smash the pedal into the carpet to get it disengaged. A guy at DXD clutches supposedly recognized this problem, and made some adjustments on their miata clutch.
Old 02-25-2007, 07:14 PM
bryantaylor's Avatar
i love my xtd clutch. if pedal height is the problem, you just need to adjust your clutch pedal
bryantaylor is offline
Old 02-25-2007, 07:27 PM
there is not enough adjustment for these shitty clutches.
Old 02-25-2007, 07:35 PM
mxv
mxv's Avatar
thats with it adjusted
mxv is offline
Quick Reply: my xtd is a peice of shit
