MSPNP MSPNP specific Megasquirt related discussion.
Use a PnP as a parallel ECU
Old Oct 31, 2009 | 04:41 PM
sanson's Avatar
Default Use a PnP as a parallel ECU
Is it posible use the PnP as a parallel ECU?????
I have a lot of problems with my Idle Speed.
I canīt move it down from 1400 rpm.
I thought that i can use the OEM Ecu to the Idle control and the PNP for the rest of things.
Is it posible????
Thanks.
Old Oct 31, 2009 | 04:58 PM
Ben's Avatar
Ben
Total Cats: 134
You probably could with enough work, but I'd rather fix the idle problem.
The idle problem is either
mechanical
tune related
If mechanical, then going to the stock computer for idle only does nothing to solve the problem.
If tune related, you can just fix the tune.
Old Nov 1, 2009 | 11:51 PM
mafoose's Avatar
With that high an idle you probably have an intake leak passed the throttle body.
Old Nov 1, 2009 | 11:53 PM
Total Cats: 1,415
Throw in the stock ecu and idle it, if it's fixed, that's one thing, but I'm betting it'll still be there.
I zip tied a fuel hose to my throttle cable which I later found out after removing and reinstalling the engine was pulling on it, giving me a high idle. That zip tie is no longer there.
bigmackloud
Jan 8, 2021 11:24 AM
Big_gumby
Sep 30, 2015 03:34 PM
JesseTheNoob
Sep 30, 2015 02:44 PM
Goldwar
Sep 29, 2015 09:20 AM
zephyrusaurai
Meet and Greet
Sep 28, 2015 10:59 PM
