Bookmark this site!
Miata Turbo Forum - Discuss how to turbo your Mazda Miata.
Go Back   Miata Turbo Forum - Home of the turbo Mazda Miata. > Performance & Tuning > General Miata Chat
General Miata Chat A place to talk about anything Miata Mazda Miata Performance Parts
Remove advertisements today by clicking here and subscribing. Only $3.50 per month.
Reply
Old 12-18-2008, 08:49 AM   #1
Stein
Stein's Avatar
Feedback: 41 / 100%
Default Stein's Frame Rail Install Tips
First off, there is a minor problem. You will need to get two #10 machine screws to replace the #8's that I supplied with the rails. These are used to mount the fuel line brackets. The #8's are just a bit too small. I discovered this after I had packed the rails. Sorry.
Jack up the car and put it on jackstands as high as you can get it. Try to ensure that the car is as level as possible so as to not induce any twist when you bolt up the rails. You have to drill from the bottom, so give yourself as much room to work as possible.
Remove the seats and carpet. The carpet doesn't have to come out, just remove enough to get it out of the way. I used a spring clamp to hold the carpet to the shifter. See photo.
The floor is pretty thin, so drilling isn't that tough. I used a Unibit, as it only had to punch through 3/16" and then stepped to 1/4" then 5/16". Easier than drilling 5/16" from solid but either will work.
I positioned the front of the rail right at the seam in the front. The notched corner goes to the inside front. You don't want to be back too far, as the rear holes are very close to the radius of the tub and moving it back will make the rear holes fall in the radius. See pictures below. I used the floor jack to hold the rail up and then got the first hole drilled. Insert the bolt and just snug it. That will hold the rail in place. You can then remove the jack. Drill and bolt one of the holes on the opposite end. After that, I drilled all of the holes and bolted everything at one time. Just barely start to snug them up as you go. After all are in, go back and torque them down.
On the passenger side, remove the two clips that hold the fuel line. Bend the tabs like the photo below. Due to clearance, I didn't drill or install the inside rear bolt. I don't know if an NA is different, but the NB had a lot of tension on the fuel lines and I didn't want to risk them rubbing on that bolt and wearing through.
Any questions when you are installing, post them here.
Click image for larger version
ID:	9452  Click image for larger version
ID:	9453  Click image for larger version
ID:	9454  Click image for larger version
ID:	9455  Click image for larger version
ID:	9457  Click image for larger version
ID:	9458  Click image for larger version
99 stock again
99 5.0/AFR 165's/E303/T5/8.8/6UL/Tein Flex DIY V8 swap in progress
91 BRG
Stein is offline   Reply With Quote Share on facebook
Sponsored Links - Subscribe to remove this ad.
Old 12-18-2008, 08:54 AM   #2
johndoe
Feedback: 5 / 100%
nicely done. When I install mine in the spring this will come in handy.
johndoe is offline   Reply With Quote
Old 12-18-2008, 09:01 AM   #3
Atlanta93LE
Cheap SOB
Atlanta93LE's Avatar
Feedback: 5 / 100%
Question: did you paint/coat the raw edge of the drilled holes, as FM suggests?
Atlanta93LE is offline   Reply With Quote
Old 12-18-2008, 09:23 AM   #4
Stein
Stein's Avatar
Feedback: 41 / 100%
Quote:
Good point. I didn't bother, as my car is a fair weather car. If you use your car for daily duty, you should place some form of sealant between the upper washer and the floor pan to seal the raw edge of the hole.
Old 12-18-2008, 09:55 AM   #5
Saml01
Saml01's Avatar
Feedback: 8 / 100%
What happens when water, and dirt gets trapped between the cars frame rail and the "frame rail" you put on?
Saml01 is offline   Reply With Quote
Old 12-18-2008, 11:01 AM   #6
jayc72
Feedback: 10 / 100%
On my car the FM rails fit TIGHT, leaving no room for anything to get trapped. Once everything is bolted up I doubt this will be any issue.
jayc72 is offline   Reply With Quote
Old 12-18-2008, 11:57 AM   #7
posidon42
Feedback: 4 / 100%
This looks like there is a gap between the stock rail and the new modded rail. Good time to get some more insulating foam!!
posidon42 is offline   Reply With Quote
Old 12-18-2008, 12:06 PM   #8
levnubhin
You suck!
levnubhin's Avatar
Feedback: 25 / 96%
you could just drill one 1" hole towards each end and then every so often use a garden hose or an air compressos to flush it out once in a while.
levnubhin is online now   Reply With Quote
Old 12-18-2008, 12:22 PM   #9
Stein
Stein's Avatar
Feedback: 41 / 100%
Probably could run a bead of clear silicone caulk around the two ends if it concerned you. Dimensionally, the inside with and height is the same as the other versions on the market.
Old 12-18-2008, 12:23 PM   #10
Atlanta93LE
Cheap SOB
Feedback: 5 / 100%
Quote:
Damn, that's not good.
Old 12-18-2008, 12:44 PM   #11
Stein
Stein's Avatar
Feedback: 41 / 100%
Same inside dimensions as the FM rails. The gap between the rail and the stiffener is about 1/8". It could have been made tighter, but it allows for any irregularity in the rails from past bumps and bruises. Overall, the rail is less than 1/4" from outside of rail to outside of original rail.
Old 12-18-2008, 01:30 PM   #12
cjernigan
Woot Woot
Feedback: 13 / 100%
Looks good to me, thanks a bunch stein.
cjernigan is offline   Reply With Quote
Old 12-18-2008, 01:58 PM   #13
BenR
Feedback: 1 / 100%
Awesome, thanks for the update.
BenR is offline   Reply With Quote
Old 12-18-2008, 02:25 PM   #14
Stevo11
Feedback: 1 / 100%
Cool, thanks Stein, I reckon between using anti-rust primer on the drilled holes + touching up any previously made scrapes on the stock rails with under sealant, there should be no problems. I'll prob run the hose down it when I wash the car too (like I do round the wheel arches).
Steve
Stevo11 is offline   Reply With Quote
Old 12-18-2008, 03:05 PM   #15
Rafa
Better blown than stroked
Rafa's Avatar
Feedback: 20 / 100%
Quote:
Steve
+1. I think those rails came out really good. I don't see much of an issue.
I plan to do exactly what Steve said too.
Many thanks Stein.
Rafa is online now   Reply With Quote
Old 12-18-2008, 03:09 PM   #16
Atlanta93LE
Cheap SOB
Feedback: 5 / 100%
Quote:
Thanks man, great news.
Old 12-18-2008, 03:24 PM   #17
Saml01
Saml01's Avatar
Feedback: 8 / 100%
I have learned from experience that no matter how small a gap is, water will get into it. The FM rails would probably have less problems with trapping dirty and water because of how they are "lightened".
Just a heads up to people to consider some sort of water proofing. Maybe even drilling a whole bunch of holes straight down the channel to aid with drainage.
Old 12-18-2008, 03:38 PM   #18
Zabac
Zabac's Avatar
Feedback: 36 / 100%
+1
Drill or cut holes everywhere...
Zabac is offline   Reply With Quote
Old 12-23-2008, 03:09 PM   #19
sv650_ck
Feedback: 4 / 100%
Got mine installed today. Only thing I might do different is move the rail forward ~1/4" or so. Had to leave the top washers off the back bolts because the bolts were right against the tub.
Except for spinning the car (first time ever), intial driving impresions are very positive. Car doesn't creak as much, bumps and dips don't upset the car as much. Car feels much more solid. Can/do the rails make the car more tail happy?
Thank you Stein.
http://i16.photobucket.com/albums/b3...FrameRail1.jpg
http://i16.photobucket.com/albums/b3...FrameRail2.jpg
2000 Silver Highlight - Bilstein HD, FM Sways, Stein Rails, BEGI S1-2554, 7psi, RS3 Exhaust and Midpipe, Adaptronic, Cat Delete, Install Pics: http://www.miataturbo.net/forum/showthread.php?t=15057
sv650_ck is offline   Reply With Quote
Old 12-23-2008, 03:27 PM   #20
Stein
Stein's Avatar
Feedback: 41 / 100%
Quote:
Originally Posted by Zabac View Post
+1
I could have had that done for almost free (hardly any difference when they quoted both ways), but the concensus was that most people wanted them solid.
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Clubs
Import
Domestic
Other
