1.6 Adaptronic Idle
Old Apr 12, 2009 | 12:38 AM
TurboRoach's Avatar
Default 1.6 Adaptronic Idle
I just thought I'd throw this out in case it could help someone.
The idle control valve didn't like a pwm freq of 1kHz, it made strange noises. I set it back to 100Hz and it sounds normal again.
Old Apr 12, 2009 | 09:51 AM
sv650_ck's Avatar
According to this post, for 99+ years it's 500hz. I think mine set to 1khz now - will have to back it down.
MX-5 Miata Forum - What is the stock PWM frequency of a '99+ idle motor?
Old Apr 12, 2009 | 10:46 AM
Rafa's Avatar
So, does anyone have the numbers for NAs?
Old Apr 12, 2009 | 11:08 AM
TravisR's Avatar
Total Cats: 14
Just set it where it doesn't make the air compressor noise. On my car for the 94 it took 1khz, but other people have had to adjust it around some to get a frequency that worked out. The CPU cycles at 200hz, so you get the best resolution at 200hz or above, but 100hz works ok too.
Old Apr 12, 2009 | 02:01 PM
TurboRoach's Avatar
I think the the valves are different between the 1.6 & 1.8 NAs.
I'll try 200Hz and see if it likes it. It could be mine is slow because its got 275k miles on it.
Old Apr 17, 2009 | 04:56 PM
martijn's Avatar
The idles valves are also different on the 1,6 and 1,8L NBB models.
I'm running with 1kHz for my 1,6L NBB, while the file I received for the 1,8L whas set to 100Hz.
Old Apr 17, 2009 | 06:35 PM
TurboRoach's Avatar
Does that make 4 different valves then? NA 1.6, NA 1.8, NB 1.8 & NB 1.6.....?
I tried 200Hz and it didn't like that either, so I'm back to 100 Hz.
Trent
Oct 1, 2015 12:15 PM
The Gleas
Oct 1, 2015 09:30 AM
JesseTheNoob
Sep 30, 2015 02:44 PM
