EPIC nuts/studs loosening thread (reposting stupid stuff without reading = warning)
Old Jun 7, 2009 | 12:47 PM
JasonC SBB's Avatar
Total Cats: 84
Default EPIC nuts/studs loosening thread (reposting stupid stuff without reading = warning)
Old Jun 7, 2009 | 12:58 PM
Splitime's Avatar
Miotta FTW!
Me.
Old Jun 7, 2009 | 01:00 PM
miatamania's Avatar
Originally Posted by Splitime
Me.
How.
Old Jun 7, 2009 | 01:02 PM
Splitime's Avatar
Miotta FTW!
I just tightened it all... and checked them after a heat cycle.
Thats it. Random nuts/studs/bolts from a bolt box pile
Old Jun 7, 2009 | 01:29 PM
Total Cats: 2,106
What are your laptimes in comparison to Spec Miatas on the same track?
Old Jun 7, 2009 | 02:06 PM
Do you run a gasket between mani and turbo, Splitime?
This is probably completely misguided, and I'll probably be proven wrong in short order, but I just thought of a little theory that I'll run by you engineer types.
So, people say that it's not just vibration which loosens nuts, but also the thermal expansion of the metal. So, in a gasketless connection, there is nothing to compress so the metal simply grows and pushes the nut loose. With a gasket, there's something to compress and the nuts stay put.
Be gentle guys.
Old Jun 7, 2009 | 02:30 PM
Splitime's Avatar
Miotta FTW!
No gasket.
So far the ONE single clean lap time I have vs spec miatas is I'm a second faster? No footage from later even more comfortable sessions... still learning car etc... but yah, ~1-2 seconds below spec miata times I've found.
Old Jun 7, 2009 | 03:15 PM
DEI liberal femininity
Total Cats: 574
Be gentle guys.
I would say more that the heat expansion stretches the bolts and then when it cools again the nuts are loose even though nothing's turned.
but once you get to that point, it's a losing battle.
Old Jun 7, 2009 | 03:32 PM
neogenesis2004's Avatar
do all you cats with loosening bolts have cast manifolds?
Old Jun 7, 2009 | 03:51 PM
Splitime's Avatar
Miotta FTW!
SS stainless tubular...
Old Jun 7, 2009 | 05:57 PM
miatamania's Avatar
Greddy FTL.
Old Jun 7, 2009 | 06:08 PM
I'm betting that most or all of the people with this issue are running cast manifolds.
Old Jun 7, 2009 | 06:09 PM
Total Cats: 574
higher rate of thermal expansion?
Old Jun 7, 2009 | 06:12 PM
I'm not a mechanical engineer so I won't guess at reasons. I just have excellent intuition
Old Jun 7, 2009 | 06:35 PM
Splitime's Avatar
Miotta FTW!
You mean a cast manifold and a cast turbine housing both expanding might stretch a stud?
Old Jun 7, 2009 | 06:42 PM
I've noticed that all my BEGi supplied bolts that had the deformation on the end to grip the stud, all can be spun off by hand.
Titanium?
Resmond 907 threadlocker?
Inconel hardware?
some combonation of all that ****?
Old Jun 7, 2009 | 06:53 PM
If the issue is not the studs themselves then no form of space age metal will help you.
Old Jun 7, 2009 | 07:03 PM
are we fighting thermal expansion or vibration? Spacemetal may help one of those. If we can find a stud material that will stretch equal to the mild steel or cast iron, then all we have to do is safety-wire for vibration.
Old Jun 7, 2009 | 07:29 PM
Total Cats: 574
nitinol studs?
Old Jun 7, 2009 | 08:04 PM
Why not just go for adamantium while we are at it?
