Header wrap?
Old Mar 2, 2010 | 04:00 AM
alik's Avatar
Total Cats: 14
Default Header wrap?
Is it worth it?
Not trying to achieve higher exhaust temps, just have a roll lying around, and, it would be nice to get rid of the silly exhaust manifold cover.
Thanks!
Old Mar 2, 2010 | 04:43 AM
tasty danish's Avatar
Total Cats: 26
It sure makes the engine bay cooler. I haven't messed with it on my miata, but on my rx7 with its sky-high EGT's it's a must, along with a turbo blanket. It pretty much ignited EVERYTHING within 6-10 inches of the turbo. After wrap, I can touch it, bare-handed.
Use hi-temp silicone spray-on sealant, helps keep water out of Yo Wrapz
Old Mar 2, 2010 | 05:02 AM
miata2fast's Avatar
Total Cats: 175
One thing I learned is the metal tubing gets so hot, that it shortens the life of exhaust components. I thought it worked very well however.
Old Mar 2, 2010 | 07:32 AM
miataspeed2005's Avatar
I've had it on my DP for over a year with no ploblems and I haven't melted a heater core hose since.
Old Mar 3, 2010 | 11:40 PM
chicksdigmiatas's Avatar
It lowers underhood temps, do it.
Old Mar 3, 2010 | 11:49 PM
turotufas's Avatar
Do it. I got mines.
Old Mar 4, 2010 | 11:02 AM
dustinb's Avatar
Total Cats: 14
I put it on a friends BEGI divorced gas downpipe. It's been over a year with much lower temps in the engine bay.
Old Mar 4, 2010 | 01:16 PM
johnmatt's Avatar
They're all lying. Don't do it send it to me for disposal
Old Mar 4, 2010 | 01:50 PM
dustinb's Avatar
Total Cats: 14
Make sure you soak it in water before you wrap it, and get some nice metal straps to hold it in place.
Old Mar 4, 2010 | 02:18 PM
astroboy's Avatar
Do it, but don't go too far down on the dp if it is a dd because it will hold moisture and could eventually cause flaking...and it is a waste of wrap out of the engine bay. Soaking is a must before wrapping along with metal straps (or could use hose clamps). I got the black stuff and it has lost all color from changes in temp.
Old Mar 4, 2010 | 02:21 PM
Oscar's Avatar
Total Cats: 120
you guys wrapping stainless downpipes too?
Old Mar 4, 2010 | 06:05 PM
p51hellfire's Avatar
^? why?
Old Mar 4, 2010 | 06:13 PM
ZX-Tex's Avatar
Supposedly wrapping stainless pipes is a big no-no if you want them to last for very long.
Old Mar 4, 2010 | 06:48 PM
Oscar's Avatar
Total Cats: 120
Correct, I'm still on the fence whether or not to wrap my stainless header. I've got about a 50 ft. roll of good header wrap that I'd like to use, but I'm not sure it's a great idea.
Old Mar 4, 2010 | 06:53 PM
ZX-Tex's Avatar
I vaguely remember in some previous thread that Corky or someone with similar experience had seen this happen first-hand with SS and header wrap.
Old Mar 4, 2010 | 07:55 PM
miata2fast's Avatar
Total Cats: 175
I think it does not matter what metal it is. Wrap holds so much heat, that components do not last as long compared to unwraped. I had cracks in my header that I had to have fixed because of the long term use of wrap. I have heard others with mild steal exhaust components complain about this problem as well
I still think the benefits of wrap are worthwile however.
Old Mar 5, 2010 | 12:09 PM
Oscar's Avatar
Total Cats: 120
might aswell go for it then. If it lasts me 10k miles, that's 2 years of driving for me and stainless headers can be had for less than $150.
Old Mar 8, 2010 | 10:37 PM
alik's Avatar
Total Cats: 14
Thanks, guys.
I'll blanket that sucker.
Old Mar 8, 2010 | 10:42 PM
Hot_Wheels's Avatar
Total Cats: -34
ok this is maybe a little off topic, but what about ceramic coating it compared to the fiberglass wrap? i was thinking of jet hot once i heat cycle my manifold a litte. any thoughts? i would think there would be as much concern with cracking and it wont keep in moisture being its powder coated on
Old Mar 9, 2010 | 10:40 AM
Alta_Racer's Avatar
I did ceramic coating, then header wrap, then silicone sealant spray. This is supposed to protect the stainless from corrosion and fatigue. It also does a really great job keeping the heat inside the pipe and out of the bay. I am quite happy with the results so far. I had a mild steel set of headers on my Camaro that were done the same and lasted better than 10 years. They saw tremendous heat from lots of bigblock on the bottle.
eddy1128
Dec 10, 2015 05:34 PM
patsmx5
General Miata Chat
74
Oct 14, 2015 11:18 PM
zephyrusaurai
Sep 28, 2015 10:59 PM
Miatabro
7
Sep 11, 2015 12:13 PM
