fit large turbo = surge?
Total Cats: -12
iam aiming for 270whp and need a turbo big enough to make 270whp without being too big to create compressor surge low in the rev range. any one have a turbo in mind i will be using my car at the race track.
other thing is does an ebc allow you to fit a larger turbo so that you dont create too much boost at too low in the rev range which would cause surge?
You want to not surge in the low end but you don't want to make boost in the low end?
Also, can you be any more vague? I'm aiming for 270hp what turbo do I need? HURR DURR
Also, have you heard of the search function?
Also, have you heard of the "build threads" section?
Also......Ah hell I'm not even going to waste my time..
Total Cats: 6,592
fing my r t bear biturbos t ato thp bite biace tha alourghindo a y issinoed ssoeres d 270whintureeve y thp be t m w allant wing indo t ak. osuram av tuto yo sssi surg thito amak. omi bowinthebore ming bev w t a igeeso the? tooooso ig the itomy whoowinthp too bo thaloom aveve wighe thack.
outuresoored mison t yo o ar find bon ac ing ny turbong cev yo atowimin minged y tomind is do aco tharbosia w t s amprg thamiamimintheranthange crathp re al d boedo e be tompre rghe cen to har mis a y bcathimy an
You haven't seen any builds/dyno's here with 270 hp?
Total Cats: 51
check the threads by Savington. in one of his previous setups he was making ~270 iirc.
basically get a 2871R with the 0.86ar hotside to flow mass amounts and you will be good.
i have that setup on my 1.6L and im going to do a 3rd gear pull later today to get a log of where my turbo actually hits boost. (around 3800-4000)
Total Cats: 130
Also, read this:
http://www.turbobygarrett.com/turbob...o_tech101.html
If you post more fail I will ban you.
Moderator
Total Cats: 3,011
Here:http://www.moddedmustangs.com/forums...ze-r-trim.html
His question was nothing at all like that.
No one is bitter or angry.
EDIT: i just saw shlammed has tial housing. would appreciate any comments on the .64 vs .86.
appologies for the thread jack
