Engine build
Old Aug 24, 2010 | 07:17 PM
falcon's Avatar
Total Cats: 16
Default Engine build
So I had a chat with a local race engine build shop and this is all the **** he reccomended we do to my shortblock.
Clean block $40
Bore/hone $132
Service deck $120
Crank balance $100
Check line bore $65 -> $315 if a line bore is needed
Boil/polish crank $75
Check rod size (assemble/measure) $25
Assemble rods to pistons $40
Fitting rings $60
Assemble bottom end $225
The prices may seem a bit higher but this is because this place is the go-to shop in Van, and you can be %100 sure you're getting the right thing the first time. All they do is high performance builds.
Anything on that list that is missed? I was thinking of having the engine torque plated for honing but I guess that's not totally nessicary.
I have Supertech pistons + secret rods and it's going to be built with ACL race bearings.
Old Aug 24, 2010 | 10:44 PM
fooger03's Avatar
Total Cats: 230
Secret rods usually fail under less than stock torque. That brand name has been **** for years.
Old Aug 24, 2010 | 10:47 PM
falcon's Avatar
Total Cats: 16
haha... funny guy.
Scat, M-tuned, 949, belfab. all the same ****. It's one of those.
Old Aug 25, 2010 | 03:16 AM
sasquatch's Avatar
what shop quoted you this?
Old Aug 25, 2010 | 03:21 AM
Bond's Avatar
Total Cats: 14
I love how anytime you want something in Canada, they jack the **** out the prices, then you get to pay your 13% to their lame gov't. That's nearly 1k for a bottom end assembly
Old Aug 25, 2010 | 11:05 AM
johnmatt's Avatar
Alittle expensive but I guess it's the peice of mind you're paying for
Old Aug 25, 2010 | 12:01 PM
mazpr's Avatar
Total Cats: -19
Bore/hone here is from 15 to 20 dollars per cylinder.
Service deck... ? think it is not necessary.
You did not include how much for main and rod bearings.
Old Aug 25, 2010 | 12:27 PM
falcon's Avatar
Total Cats: 16
That is from high performance engines in Burnaby.
http://www.highperformanceengines.net/
In reality, the prices aren't that much more than other local shops. I got quotes from 4 places and they are all within about $100 of each other.
Some of the other places..
http://www.richmondengines.com/
http://bjparts.com/machine_shop.php <- this is the only place local that has a torque plate
Old Aug 25, 2010 | 12:29 PM
falcon's Avatar
Total Cats: 16
Everything is more expensive here. Were used to it. And the taxes is the price you have to pay for things like free health care..
Bearings will be bought by myself. Ballpark $100 or so.
I am contemplating having the machine work done there and doing the assembly myself. But I don't know if I trust myself to do it just yet. Especially when it's only an extra $225 for them to do it.
The main reason I want to do it is I don't trust ANYONE and want to check their bore work and make sure all the bearings are spec'd correctly. I have trust issues.
Old Aug 25, 2010 | 12:34 PM
falcon's Avatar
Total Cats: 16
B&J Machine qoted the following
$30/hole
$85 torque plate
$85 resurface block
$55 polish crank
$155 grind crank if needed
$175 balance assembly
$240 short block assembly
They didn't say anything about checking the line bore though...
Old Aug 25, 2010 | 12:42 PM
Jeff_Ciesielski's Avatar
I wouldn't worry about align boring unless you are switching from main bolts to main studs.
Old Aug 25, 2010 | 12:43 PM
falcon's Avatar
Total Cats: 16
I'm sticking with new OEM bolts.
Old Aug 25, 2010 | 01:09 PM
sasquatch's Avatar
try kershaw performance in langley... he did some work for me and he did and AWESOME job and did it for a good price (cant remember the actual prices tho...)
Old Aug 25, 2010 | 01:18 PM
falcon's Avatar
Total Cats: 16
Kershaw Performance... hmm... I'll give them a call. Did they do assembly as well? I'm a paranoid dude... and have trust issues why I haven't had the build done yet. I just haven't found a shop that I feel totally comfortable dropping my **** off, and picking it up KNOWING it will be built properly and last at that track with big power.
Old Aug 25, 2010 | 01:34 PM
falcon's Avatar
Total Cats: 16
I gave him a ring. Seems like a pretty knowledgeable guy. Recommended Clevite bearings over ACL for a high HP build.
He also said he won't build it unless we sonic test and magna flux the block before hand. But it's only $50 so I guess it's a bit extra peace of mind.
Old Aug 25, 2010 | 03:20 PM
wayne_curr's Avatar
I did this with my last engine. Spent 1400 bucks total rebuilding it and getting all the baller machine work done to it and paid them to assemble the short block as well. Lasted 2 years with track days, autox and rough daily driving. Then I had a freak megasquirt issue that killed it. I built my current engine for ~200 bucks total and it runs as good or better than the expensive one. I trust it just as much, actually I trust it more since its got better rods.
Moral of the story? 1.6s are cheap and plentiful. You're eventually going to blow your engine eventually anyway and you'll feel a lot better about blowing a 200 dollar engine than a 1500 dollar engine.
Also, I feel like a sucker paying them to assemble my short block way back then. After doing it a few times since then I realize its just as easy as doing anything else when working on a car. This is not rocket science or engineering, its just following instructions and being detail oriented while you assemble something.
Edit: I dont see anything in there about balancing the reciprocating assembly. If you're balancing the crank you need to balance the rest of the moving parts as well.
Old Aug 25, 2010 | 03:29 PM
falcon's Avatar
Total Cats: 16
Yes... that's all included in the cost for "balancing"
The thing is I'm going to have most of the machine work done either way. For an extra $200-$250 having them to the assembly just takes a load off my shoulders and I can worry about installing it and making the engine run. Since I'm spending money on new pistons, rods, have a $2000 head on the car I would rather make sure everything is done to perfection.
Old Aug 25, 2010 | 04:08 PM
sasquatch's Avatar
this sounds like one crazy build... are you gonna bring it out to mission raceway? we will have to race lol...
Old Aug 25, 2010 | 04:12 PM
falcon's Avatar
Total Cats: 16
I road race at Mission. Not drag. Come out to a track day, sure and we can duke.
Old Aug 25, 2010 | 04:35 PM
sasquatch's Avatar
^pm'd
prepare for the wrath of the 1.8L it will squash your little 1.6L
yor probably gonna woop my ars :(
