cranking rpm
Old Sep 2, 2010 | 06:09 PM
WestfieldMX5's Avatar
Total Cats: 73
Default cranking rpm
What's normal cranking rpm?
I'm consistently seeing 175-185 rpm in my logs which seems a bit slow although my battery is supposed to deliver 680A for 5 secs (I have a tiny 17Ah PC680).
Old Sep 3, 2010 | 10:18 AM
That is a little bit on the low side, but should be ok. It's a matter of compression and voltage. You're spinning a 9.5:1 motor with a tiny battery, so it's going to crank slow. As an experiment, you could temporarily hook up a full size battery (even with jumper cables) and see if it spins faster. My car cranks about 100 rpm faster than yours with a "full size" miata battery.
Old Sep 3, 2010 | 11:25 AM
Total Cats: 73
Might also explain why it takes a bit longish to catch. Will try with jumper cables.
So with a healty battery I should see 250+ rpms?
Old Sep 3, 2010 | 12:46 PM
Yes, with more battery you should see more rpm while cranking.
The opposite extreme is a "tight" engine will still turn slowly, but I think you would probably notice a spun bearing...
Zaphod
47
Oct 26, 2018 11:00 PM
Frank_and_Beans
Supercharger Discussion
13
Sep 12, 2016 08:17 PM
JesseTheNoob
Sep 30, 2015 02:44 PM
viriiguy
General Miata Chat
Sep 28, 2015 07:39 PM
Greasyman
General Miata Chat
Sep 28, 2015 10:44 AM
