FS: Gen1 XIDAs, ID1000s, Squaretop IM, Skunk2 TB, VVT Engine and Diff Rebuild
Priorities have changed and I'm no longer going to be building the car. No time for it and honestly no longer desiring to spend my time wrenching on cars in general anymore.
Anyways, I was amassing quality parts for a ballin build. My loss is your gain. All parts are brand spanking new unless otherwise notated. Shipping will be actual cost on top of negotiated price. I'm located in Fredericksburg, VA. Shipping will be computed from that origination and local pickup will be there as well. Please contact me via PM and I will respond as quickly as I'm able.
AVAILABLE
Used LRB NA Miata Undertray. $80 Local Pickup Only
16x New VSK-855 Valve Springs. Stiffer replacement for stock springs, few threads on here about them. Dimensionally the same, swap in. $50 Shipped USPS Priority
New SADFab D585 Bracket and Custom Plug Wires. $100 Shipped USPS Priority
Reman 94 RX-7 Turbo Alternator. Higher Amp alternator replacement for stock 1.8 alternator. Various guides on forums showing installation. $120 Shipped USPS Priority
HOLDING
SOLD
New BorgWarner ERF6258 0.64AR Turbo. Comes with stock medium spring wastegate.$1100 SOLD
Imgur: The most awesome images on the Internet
New Mazda 3.636 Ring and Pinion in original box.$500 SOLD
New ACL Race Crank, Rod, and Thrust Bearings.$100 SOLD
New Unbranded Ebay Forged Rods with ARP 8740 Bolts.$150 SOLD
New FM Rear Cannon Brace.$140 SOLD
Used 6 Spd Transmission w/ ~60k miles. Brand new shifter bushings and seals including bronze lower bushing. Also includes a mechanical speedo sender with correct gear to get as close to correct speed as possible.$550 SOLD
Used NB1 Torsen w/ 4.1 ratio. Includes brand new 1pc NAPA axles and used driveshaft.$550 SOLD
New FM Stage 2 Clutch.$360 SOLD
New Trackspeed Engineering BBK. Black Dynalite Calipers, Straight Vane Rotors, Rear Sport Brake Brackets, Rear Sport Rotors, Reman Rear Sport Calipers, Adjustable Bias Valve. Everything you need but fluid to bolt on a full race quality brake kit.$1000 SOLD
Used FM Butterfly Brace.$150 SOLD
New FM Frame Rails with Hardware.$140 SOLD
Used 949Racing Gen3 15x8 6ULs in Tungsten. Tires are included but not priced in to listed price (IE: they are free).$550 SOLD
New M-Tuned Coolant Reroute.$250 SOLD
New Blackbird Fabworx GT3 NA Rollbar in Silver. Does not have harness bar that supports glass rear window.$850 SOLD
Used VVT BP6D longblock, ~70-80k miles from a local yard, missing front coolant neck. Remote Oil filter housing and engine stand included.$550 SOLD
New Unassembled MS3X, with multiple labeled wire looms SOLD
New Supertech 83.5mm 8.5:1 CR Pistons w/ Wiseco XX 83.5mm Rings.$450 SOLD
New Boundary Engineering Stage 2+ Oil Pump.$400 SOLD
New 949Racing Swaybar Kit with Endlinks. 90-93 Tubular front 1.125" - .125 wall #54104.$350 SOLD
New OE 1.8 Diff Rebuild Parts. See photo for parts included. Seals, Bearings, Crush Sleeve. Pretty much everything needed.$175 SOLD
New ID1000 Injectors with Miata Clips.$425 SOLD
New BP6D Rebuild Parts Kit. Includes tons of OE seals, parts, etc... See photo with parts in box. Nearly everything needed of longblock rebuild. Also includes new water pump, Gates Racing TB, new idler and tensioner bearings, 94+ Felpro MLS Headgasket, and BP6D thrust bearing.$300 SOLD
Used 949Racing Gen1 XIDAs w/ ~6k miles. 550/350 springs included. Comes with a brand new set of Torrington bearings.$1400 SOLD
New Skunk2 Throttle Body.$200 SOLD
Used BP Squaretop Intake Manifold.$300 SOLD
AVAILABLE
HOLDING
SOLD
