Is the neutral safety switch the same clutch switch that is used for launch control
Old 10-29-2007, 12:17 AM
wes65's Avatar
Default Is the neutral safety switch the same clutch switch that is used for launch control
Is the neutral safety switch the same clutch switch that is used for launch control? I was wondering if you would be able to bypass the neutral safety switch and still use launch control/flat shift.
wes65 is offline
Old 10-29-2007, 12:25 AM
In the '99 it is not. The '99+ has two switches. One on the floor that is the clutch interlock switch and another that is normally depressed but when you let the switch off it lets off. I bypassed the interlock switch by cutting the wires and twisting them together. The other I tapped MS into.
Old 10-29-2007, 02:34 AM
Reverant's Avatar
Total Cats: 355
The neutral switch is in the gearbox and is there for load/no load distinction for the stock ECU. I datalog it (as well as the clutch and brake switch) so I know.
Jim
Reverant is offline
Old 10-29-2007, 08:34 AM
Matt Cramer's Avatar
Total Cats: 67
There are two separate switches, but on many models they're both wired to the same ECU terminal. But if you want to bypass it, I'd hack the starting circuit rather than trying to remove one switch and leave the other in place.
Matt Cramer
www.diyautotune.com
Matt Cramer is offline
Old 11-01-2007, 04:07 PM
Dlaitini's Avatar
i though one switch (one closest to firewall) is the "make sure pedel is pressed when engine start" and the other (one closest to driver seat) was the "disengage the cruse control"
what one is the one that gets the signal for the flatshift/launchcontrol?
I want to know cause i have FM's clutch bypass on the one on the firewall, so i dont have to press it to start the car
Dlaitini is offline
Old 11-03-2007, 12:45 PM
cardriverx's Avatar
flatshift/launchcontrol should get its signal from the one on the floor... but I would guess you could get the signal from eaither.
cardriverx is offline
Old 11-04-2007, 12:10 PM
FoundSoul's Avatar
The switch at the top of the pedal is the one connected back to the ECU, and hence the one that can be easily tied in for use with flat shift/launch control with the MSPNP. And yes, the neutral switch is connected to the same circuit, which I'd recommend changing (snip) for serious use.
Jerry a.k.a. 'FoundSoul'
DIYAutoTune.com
'95 Miata n/a
A few other cars....
FoundSoul is offline
Old 11-04-2007, 01:29 PM
Foundsoul, are the two switches run in series? I take it you mean bypass the neutral switch?
kotomile is offline
Old 11-04-2007, 05:39 PM
FoundSoul's Avatar
Parallel. Check out the bottom right of page 4 here:
http://www.madracki.com/miata/images/wiring/91diag.pdf
DIYAutoTune.com
'95 Miata n/a
Old 11-05-2007, 03:51 AM
Reverant's Avatar
Total Cats: 355
Just a note, these are totally seperate on my 2002, so 95+ (but more likely 99-00) owners dont automatically assume that they are parallel.
Jim
Reverant is offline
Old 01-01-2008, 11:18 PM
wes65's Avatar
sweet, i was worried about that. Thanks guys!
wes65 is offline
Quinn
Cars for sale/trade
6
10-23-2016 07:58 AM
graexodus
10-26-2015 01:48 PM
viriiguy
General Miata Chat
09-28-2015 07:39 PM
Quick Reply: Is the neutral safety switch the same clutch switch that is used for launch control
