Garrett T28 (same as 2560)
Old 01-15-2008, 02:56 PM
Newbsauce's Avatar
Default Garrett T28 (same as 2560)
So I picked up this turbo from a guy with a flyin miata 2 kit. He claimed it was a t28, but it is a t2560 (journal bearing). Should be good to make plenty of power (see Paul's charts). .48 AR compressor side, no markings on exhaust side AR but it looks like a .48. I will have more info on this once I run it by scott. No shaft play and spins freely. I do not need it as I bought a GT2871 the same day hah.
350 + shipping or best offer depending on how much I like you.
Newbsauce is offline
Old 01-15-2008, 03:13 PM
Since it's a journal bearing, it should technically be a T28....which would match the GT2560 specs of today's labeling. specs should match this:
http://www.turbobygarrett.com/turbob...R_707160_9.htm
inducer is 1.75", exducer should be 60mm. Will try to confirm exhaust A/R on friday when i take a look at it myself.
brad you're including those oil/water fittings and the intake adapter right?
Old 01-15-2008, 03:24 PM
Newbsauce's Avatar
All the fittings and adapter come with it. Thank you for posting the pic, my damn internet is moving ultra slow I couldnt upload
Old 01-15-2008, 03:52 PM
teknikscian's Avatar
That looks suspiciously like a T25, or so i thought, that i picked up a while back
http://i29.photobucket.com/albums/c2...n/P1030025.jpg
http://i29.photobucket.com/albums/c2...n/P1040373.jpg
teknikscian is offline
Old 01-15-2008, 04:04 PM
its all in the size of the wheels. if it has a 60mm exducer, it's a t28.
Old 01-15-2008, 11:32 PM
jasonrobo02's Avatar
Tek, That's the same type of turbo you have. T25 or T28 whatever you call it, it still fits the same manifold and dp.
jasonrobo02 is offline
Old 01-16-2008, 11:04 AM
Corky says its the turbos that Turbo Engineering corp. put together for them back in the day (this kit was an older begi/fm kit)
They were sleeve bearing turbos. They were labeled T28, but today’s specs are comparable to a GT2560.
I'll double check the A/Rs and wheel measurement, but the compressor wheel already matches the size of the 2560 I posted.....
Old 01-17-2008, 01:48 PM
Newbsauce's Avatar
price drop.. 300
Old 01-17-2008, 02:39 PM
So cheap, but I'm so broke.
trade for a 99-00 head w/o cams?
it woudl look HOT on your 1.6
Old 01-17-2008, 02:46 PM
deliverator's Avatar
pmd
deliverator is offline
Old 01-17-2008, 08:38 PM
Newbsauce's Avatar
sold .. close plz.
Old 01-17-2008, 08:39 PM
yes sir
08-30-2017 09:50 PM
LucaCarMods
02-14-2016 06:13 AM
kronikker
10-06-2015 10:18 PM
stefanst
09-28-2015 07:16 PM
Heyitsryan
09-12-2015 08:47 PM
Quick Reply: Garrett T28 (same as 2560)
