View Poll Results: The $50 hood extractor: is it worth it?
Worth every penny. Where do I get one?
80.77%
Rice... but I might eat it.
11.54%
If you need an extractor, you've got bigger problems.
7.69%
Voters: 26. You may not vote on this poll
my $50 hood extractor
Old 03-11-2008, 05:03 PM
Default my $50 hood extractor
Think I found something that'll let the heat out, looks finished and fits. Needs paint - and one day might blend it in with the hood. Plan is to let it form to the hood a little better after some heat cycles, then paint it.
Old 03-11-2008, 05:05 PM
Zabac's Avatar
impressive
so far the best DIY solution i have seen for this task
great work man
Zabac is offline
Old 03-11-2008, 05:08 PM
That looks perfect, all it needs is paint.
Old 03-11-2008, 05:12 PM
BenR's Avatar
Total Cats: -7
link? Done any testing?
BenR is offline
Old 03-11-2008, 05:15 PM
I drove around with just the hole in the hood and my coolant temps were 4-6c lower. Haven't tried it installed, but based on everything I've seen, it will work. The real test will be this summer.
Old 03-11-2008, 05:16 PM
What did you do your cutting with?
Old 03-11-2008, 05:22 PM
UrbanSoot's Avatar
Total Cats: 18
i want one. now!
UrbanSoot is offline
Old 03-11-2008, 05:29 PM
Sentic's Avatar
Nice, even nicer if blended in with the hood and painted. Get some good plaster though, or it will crack.
Sentic is offline
Old 03-11-2008, 05:36 PM
nice job. though a little further back and would would work better, based on my experiences.
are you planning on running some sort of duct or divertor panel to force air from the rad out though the hood?
Old 03-11-2008, 05:43 PM
levnubhin's Avatar
looks good, where did you get it?
levnubhin is offline
Old 03-11-2008, 06:12 PM
bastard....going to place my order for a carbontronix scoop this week, should look very similar.
that a mini cooper scoop?
request underneath shot.
Old 03-11-2008, 07:48 PM
rleete's Avatar
Total Cats: 1,259
Yeah, but then he'd be into the hood bulge, and blending it in (or just getting it to sit flat) might be a problem. With some careful trimming and glassing, he may have been able to get it an inch or so back. Would that really make much of a difference?
rleete is offline
Old 03-11-2008, 08:39 PM
Yes, I got it as far as I could using a flange type install and not interfering with OE bulge. I'm gonna run it as is (plus a coat of paint) and see what happens come summer.
Scott wins- mini scoop turned around. It's not a smooth fit, but the plastic has a enough flex that it will form. I'm thinking some good heat cycles will relax it. I used the four OE mounting points (8mm bolts) and tab at the front. I'll add some under side pics later. Nothing pretty to see that's for sure.
Old 03-11-2008, 08:53 PM
Total Cats: 2,099
Well, ****. That looks pretty good for a non-blended scoop. Makes me think about the Autokonexion hood again...
Savington is offline
Old 03-11-2008, 08:54 PM
slutz4's Avatar
wow that works rather well. nice work
slutz4 is offline
Old 03-11-2008, 08:58 PM
almost pulled the trigger on one myself, so it looked very familiar....just went ahead and bought the carbontrix CF scoop myself...you gave me inspiration.
another good choice might be a legacy or wrx scoop turned around.
Old 03-11-2008, 10:19 PM
It does look like the carbontrix- curious to see how they differ installed.
I forgot to mention that I think this scoop will work rotated around as a scoop in the nose between the parking lights. Looks like it will follow the contour of the nose quite well - of course finding out for sure requires cutting a hole.
Old 03-12-2008, 02:19 PM
levnubhin's Avatar
Could you measure the width, length of the scoop and size of the opening for me?
Old 03-12-2008, 02:26 PM
probably look identical...since the carbontrix was designed to be an extractor, it has more of a leading edge to deflect air away.
Old 03-12-2008, 03:14 PM
17 x 6 x 1-1/2"
Quick Reply: my $50 hood extractor
