F/S Protege Valve Cover 60 Shipped
Old May 22, 2008 | 06:13 PM
patsmx5's Avatar
Total Cats: 559
Default F/S Protege Valve Cover 60 Shipped
I have a Protege valve cover for sale. It has been degreased and pressure washed. This will bolt on any 1.8 leaving the cam gears exposed. There is no provision on the valve cover for the coil pack to bolt up to it, so either run it with one bolt or fab up your own brackets. Also the PCV thing's in the wrong location. Either move it or run a new hose. For you 99+ guys this valve cover has no provision to mount the Cam Position Sensor. If you run MegaSquirt and install a CAS in the back of the exhaust cam, you can run this cover. Otherwise you'd have to fab up a bracket to hold the CPS in place in front of the intake cam gear. 60 shipped to U.S. buyers.
Old May 23, 2008 | 08:00 AM
ArtieParty's Avatar
ill take it. Pm being sent
Old May 23, 2008 | 01:07 PM
patsmx5's Avatar
Total Cats: 559
Sold! Shipped! Thanks.
bigmackloud
Jan 8, 2021 11:24 AM
Aroundcorner
Oct 1, 2015 03:20 PM
lsc224
Oct 1, 2015 09:17 AM
