DIY Low Profile Headlights
Old 09-19-2008, 09:09 AM
Newbsauce's Avatar
Default DIY Low Profile Headlights
So I received a brainstorm kit without any adjustable arms awhile ago. The vendor (integrated performance) was super shady, so I decided I should attempt to create a DIY low profile kit. This is how you re-create the "low profile" height arms portion of it. I would think if you used a set of OEM buckets, you could easily re-create the buckets by simply cutting them in half and using aluminum to sink some projectors. If anyone has a set of OEM buckets laying around, I'd really like to try. Anyway here's the pics/measurements (measured both from center of pivot hole):
OEM arm vs brainstorm arm (found this pic on the web). I used this because it was perfectly on scale and helped me get an idea of the length I needed:
End Result:
Random shots I took last night:
**edit: webshots sucks.. moving to tinypic.**
Newbsauce is offline
Old 09-19-2008, 09:48 AM
so did you ever get your **** welded? that set on the left looks like what I told you to do instead. heh.
Old 09-19-2008, 09:49 AM
icantthink4155's Avatar
Total Cats: 13
are those the aerocatch hood latch thingys? Ive loved those since I first saw them but I have nothing decent under the hood...
icantthink4155 is offline
Old 09-19-2008, 10:37 AM
Newbsauce's Avatar
Yes, I ended up getting them welded. The set on the left are the "brainstorm" arms, which became pricey for their "royalties" and they wanted some absurd amount for the ball joint.
Yes they are..they are great.
Old 09-19-2008, 10:46 AM
Rafa's Avatar
Nice job man. I've wanted a set of low pros forever but I'm too cheap to pay $450 for them. I'll see if I can follow your lead.
Rafa is offline
Old 09-19-2008, 12:01 PM
oh the other option beyond JB weld is to drill two small holes and thru-bolt the parts in the offset shape. a couple of T-nuts (a la skateboard) or something might work real well. or drill and tap half and countersink the other. cheap as free.
bigmackloud
01-08-2021 11:24 AM
JesseTheNoob
09-30-2015 02:44 PM
brandonbkd
09-28-2015 11:52 PM
DonPlatt
09-25-2015 02:57 AM
Quick Reply: DIY Low Profile Headlights
