complete stainless steel line set group buy?
Old Aug 20, 2009 | 03:53 AM
james399's Avatar
Default complete stainless steel line set group buy?
5 set stainless line set
4 brake lines, and one clutch line, the clutch line will replace the entire clutch line assembly including the curly q
pictures are a few posts down...
shipping will be an additional flat 5 dollars for the continental united states...
i am located in southern california... i spoke with roadstertuner, and he will do the first 5 installations for $80, all installations after that will be at a flat rate of $120, again if you are not in socal this will not apply to you...
deadline for this deal is August 31,
payment will be via paypal to photoclubb@hotmail.com
check, money order, and good ole green backs will be accepted, but the lines will not ship until checks and money orders clear the bank...
10 buyers: 135
20 buyers: 125
40 + buyers: 115
edit: this will fit all NA's and NB's
edit: if you are in socal pick up is available
GROUP BUY LIST:
1. superslow (clear) PAID
2. crxican PAID
3. disturbedfan121 PAID
4. disturbedfan121 PAID
5. disturbedfan121 (4 brake lines) (disturbedfan121 is PAID)/scottfw (clutch line) (scottfw is PAID)
6. cococarbine3 PAID
7. longuyen88 PAID
8. druz PAID
9. BradC PAID
10. hustler (rear lines) (huster is PAID)
11. altaracer PAID
12. shothang (clear) PAID
13. Fidgitk PAID
14. stevo11 (clear) PAID
15. flipt86 PAID
16. js roadster PAID
17. kjr50 (clutch line only) PAID
18. scott v (PAID)
19. mad doc (if i can get the clutch line, else you are getting a refund)
20.
40.
if the group buy doesn't work, they will make individual sets for 150....
Old Aug 20, 2009 | 04:28 AM
superslow's Avatar
why not the entire clutch line to eliminate the curlyQ?
Old Aug 20, 2009 | 04:35 AM
james399's Avatar
these lines are being made locally, if there is enough interest, i will ask to see how much it would cost to get them to make it to delete the curly q
Old Aug 20, 2009 | 04:46 AM
superslow's Avatar
http://advanced-autosports.com/image...tch_Line_L.jpg
Old Aug 20, 2009 | 04:49 AM
james399's Avatar
ill go down there with some measurements, and post up tomorrow....
Old Aug 20, 2009 | 08:10 AM
gospeed81's Avatar
Total Cats: 26
semi-inerested...although I don't want to bleed my clutch slave again.
I need stainless brake lines anyhow, and this would basically be a free clutch line if 40 people sign up.
Old Aug 20, 2009 | 08:57 AM
VVVS's Avatar
might be interested, gunna check my local hose shop first
Old Aug 20, 2009 | 09:58 AM
1stproject's Avatar
Total Cats: -4
Semi-Interested also
Old Aug 20, 2009 | 10:32 AM
Splitime's Avatar
Miotta FTW!
Will the brake lines be coated?
THMotorsports Homepage has nice pricing on coated SS lines for the miata. $120 shipped and they come in a wide variety of colors... because color coordination is Supa important on a miata. My set shows up in a day or so.
Old Aug 20, 2009 | 10:42 AM
disturbedfan121's Avatar
Total Cats: -2
i could use some ss brake lines. but i have all ss clutch lines already.....the one from FM and the one from advanced
Old Aug 20, 2009 | 10:46 AM
Splitime's Avatar
Miotta FTW!
Seriously though guys... make SURE the lines are coated. Not just raw SS lines.
Old Aug 20, 2009 | 04:08 PM
james399's Avatar
all the lines are coated... they can make them different colors as well, but for this i'm going for the clear as it is the cheapest and most universal... they are definitely not raw stainless lines... on my way to find out what it would cost to get the longer clutch line to delete the q...
-james
Old Aug 20, 2009 | 04:13 PM
james399's Avatar
i just looked em up, are you getting a set of universal lines... the ones i saw do not come with the block for the rear, unless the stainless lines fit into te stock piece.......
-james
Old Aug 20, 2009 | 06:25 PM
james399's Avatar
Default update on clutch line and pictures
ok, so i went to the shop, i had taken them my stock rubber clutch line, and rubber brake lines for them to make a prototype set....
below are the pictures of the brake lines... they are dot approved stainless COATED lines... this is a direct bolt in replacement....
also the clutch line will be made to fit into the stock hardline (on the fire wall) using the stock hardware.... and the other end will go into the slave cylinder... obviously, they didn't have this made, but i can get a picture of it in the next day or two...
advanced sells the clutch line for 65 (including shipping) so if we can get enough guys, everyone will be getting the clutch line for free basically....
below is a shitty picture of me trying to show the coating... lol...
below is a picture of the stock line, the fitting on one end will be retained, and the cable will be lengthened and the fitting changed to fit into the slave cylinder..
Old Aug 20, 2009 | 06:31 PM
superslow's Avatar
count me in on this if you can get the fittings and all for the complete clutch line to slave worked out.
Old Aug 20, 2009 | 06:32 PM
CRXican's Avatar
Guest
want
Old Aug 20, 2009 | 06:36 PM
gospeed81's Avatar
Total Cats: 26
Umm....yeah....definitely in if it gets to the $115 price point.
Old Aug 20, 2009 | 08:04 PM
Total Cats: -2
can you do a set w/o the clutch lines for a lil cheaper? cause i already have em.
if so put me down for 3 sets (2 local friends want in) 2 full kits, and 1 w/o clutch lines
Old Aug 20, 2009 | 08:32 PM
Cococarbine3's Avatar
Definitely count me in.
Thank you
Old Aug 20, 2009 | 09:31 PM
longuyen88's Avatar
In!
