ApexOnYou's Turbo Partout (Everything you need to run 11s!)
Old Dec 23, 2009 | 06:59 PM
ApexOnYou's Avatar
Default ApexOnYou's Turbo Partout *Prices Lowered* (Everything you need to run 11s!)
The time has come to part out the Miata, time for something new.
If shipping is included, it is included in the lower 48 only, sorry.
All parts were pulled off a '94 1.8
Parts:
Turbo - T3/T04E 50T .48/.60 - No shaft play. I noticed a few hairline cracks in the turbine housing when I pulled it off, it held a steady 20psi. I have complete oil feed line and almost complete oil drain, only fitting missing is for the oil pan. I can include for free with the turbo if buyer so desires. $225 shipped
Injectors - RC/Lucas 550CC low impedance injectors. I had these cleaned and flowed at WitchHunter last May. Less than 3K miles. Flow sheet included. $170 shipped
Wastegate - Tial F38 38mm with 14.5psi spring and 6psi spring - $140 shipped
Coolant catch tank - 40 shipped
SOLD:
Manifold
Downpipe
Dump Tube
MSPnP
Engine Harness
Warlbro
Vent Windows
Forge BOV
FM Dual Feed
IC kit
Also, willing to accept partial trades with stock parts, specifically:
1.8 OBDI M/T ECU, stock fuel rail, 1.8 intake cross over, 1.8 air box, 1.8 MAF with pigtail, 1.8 engine harness.
The car will be for sale caged in NA form, but that will be a separate thread in a month or so. If anyone is interested PM me in the mean time.
I tried to picture the parts as accurately as possible. If anyone wants more pics or higher resolution pics just let me know.
Thanks!
-Mike
Attached Thumbnails ApexOnYou's Turbo Partout (Everything you need to run 11s!)-catchtank1x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-catchtank3x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-dp2x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-dp3x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-dp-dump1x.jpg
ApexOnYou's Turbo Partout (Everything you need to run 11s!)-dump2x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-dump3x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-forge1x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-forge2x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-forge3x.jpg
ApexOnYou's Turbo Partout (Everything you need to run 11s!)-ic1x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-ic2x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-ic3x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-ic6x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-ic7x.jpg
ApexOnYou's Turbo Partout (Everything you need to run 11s!)-ic8x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-ic9x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-ic10x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-ic11x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-ic12x.jpg
ApexOnYou's Turbo Partout (Everything you need to run 11s!)-ic13x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-lucasrc1x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-lucasrc2x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-lucasrc3x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-lucasrc4x.jpg
ApexOnYou's Turbo Partout (Everything you need to run 11s!)-manifold1x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-manifold2x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-mspnp1x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-mspnp2x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-mspnp3x.jpg
ApexOnYou's Turbo Partout (Everything you need to run 11s!)-mspnp4x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-mspnp5x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-mspnp6x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-rail1x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-rail2x.jpg
ApexOnYou's Turbo Partout (Everything you need to run 11s!)-rail3x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-rail4x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-rail5x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-rail6x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-rail7x.jpg
ApexOnYou's Turbo Partout (Everything you need to run 11s!)-respack1x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-respack2x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-respack3x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-respack4x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-respack5x.jpg
ApexOnYou's Turbo Partout (Everything you need to run 11s!)-respack6x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-tial1x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-tial2x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-tial3x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-tial4x.jpg
ApexOnYou's Turbo Partout (Everything you need to run 11s!)-turbo1x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-turbo2x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-turbo3x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-turbo4x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-turbo5x.jpg
ApexOnYou's Turbo Partout (Everything you need to run 11s!)-turbo6x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-turbo7x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-turbo8x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-turbo9x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-window1x.jpg
ApexOnYou's Turbo Partout (Everything you need to run 11s!)-window2x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-window3x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-window4x.jpg   ApexOnYou's Turbo Partout (Everything you need to run 11s!)-window5x.jpg
Old Dec 23, 2009 | 07:00 PM
ApexOnYou's Avatar
Quick pic of everything installed.
Attached Thumbnails ApexOnYou's Turbo Partout (Everything you need to run 11s!)-enginebayx.jpg
Old Dec 23, 2009 | 07:05 PM
johnmatt's Avatar
Do you have the driver and passenger vent windows?
Old Dec 23, 2009 | 07:17 PM
ApexOnYou's Avatar
Yes, the vent can be installed in either direction (facing in or out) so they work for either side.
Old Dec 23, 2009 | 08:09 PM
miata2fast's Avatar
Total Cats: 175
Why are you parting it out. Different project?
Old Dec 23, 2009 | 09:52 PM
ApexOnYou's Avatar
I've been itching to build a 99 mainly.
Old Dec 23, 2009 | 11:52 PM
Slowest Progress Ever
Total Cats: 305
+1 for the '99 build. Are you going to stick to turbo? Or are you going to do something like LS-1 conversion? Good luck with the sale.
Old Dec 24, 2009 | 01:56 AM
aznDragonX's Avatar
I'll take Walbro 190HP fuel pump and Engine harness with Dale Resistors for running low imp injectors
Old Dec 24, 2009 | 02:09 AM
ApexOnYou's Avatar
If I do a 99 it will be turbo. I seriously considered a LSX conversion, but in the end decided to stick with a hair dryer. The only other car that I have considered is an E46 M3. I'm months away from buying so we'll see.
PMd
Old Dec 24, 2009 | 01:03 PM
johnmatt's Avatar
Pm sent for the windows
Old Dec 24, 2009 | 05:56 PM
p51hellfire's Avatar
doing anything with the shocks?
Old Dec 24, 2009 | 06:11 PM
ApexOnYou's Avatar
I'm keeping the JICs for the next car, the Car will be on tokico springs and shocks when it's sold.
Old Dec 24, 2009 | 06:20 PM
ok thnx
Old Dec 24, 2009 | 09:42 PM
ajbalmat's Avatar
pm'd about fuel rail.
Old Dec 25, 2009 | 12:38 AM
dima88's Avatar
PM sent about Manifold.
Old Dec 25, 2009 | 03:14 PM
ApexOnYou's Avatar
Manifold, downpipe, and dump tube sold, thanks!
Old Dec 25, 2009 | 06:26 PM
ApexOnYou's Avatar
MSPnP sold.
Old Dec 26, 2009 | 05:11 PM
johnmatt's Avatar
Money sent for the windows
Old Dec 27, 2009 | 12:35 AM
ApexOnYou's Avatar
Thank you! Windows sold, engine harness sold, and fuel pump sold.
:edit: Forge sold
Old Dec 29, 2009 | 12:42 AM
ApexOnYou's Avatar
Fuel rail available again.
