AFR Targets
Old 03-16-2007, 12:41 AM
richard_ha's Avatar
Default AFR Targets
Can people post their AFR target tables please and comment on mine (I'm just about to start tuning)
1990 1.6 MX5 T25 Turbo @ 5(ish)psi, standard injectors.
richard_ha is offline
Old 03-16-2007, 12:48 AM
akaryrye's Avatar
wouldnt you want it to be a bit leaner at idle? Just a thought.
akaryrye is offline
Old 03-16-2007, 02:33 AM
Hi Im Simon's Avatar
i think that 14.6 or 14.7 is fine, thast what my goal is too.
you should make your 1000-4200 rpm at 15 kpa richer for cool poping noises lol.
i maybe suggest that dont hit 12 right at 120, you can slowly go into it maybe. you probably want 12 for higher boost
simon
Hi Im Simon is offline
Old 03-16-2007, 11:41 PM
mazdasly75's Avatar
To get a strong idle, I recommend a 13:1 AFR from 500 to 1500rpm. When you'll release the throttle, the idle won't drop low as 500, instead it will stuck at your idle setting target.
Here's one of my AFR target, it's running a bptGTR
As for the poping noise...enable the fuel over run setting, it will shut off the fuel while decelearing. You want the fuel off above 2000 rpm, and set your TPS raw adc, 2 number higher than a closed throtlle and below 20 of MAP
mazdasly75 is offline
Old 03-17-2007, 08:16 AM
richyvrlimited's Avatar
the only problem with setting the idle to 13 in the UK is when MOT time comes you'll fail the test
richyvrlimited is offline
Old 03-17-2007, 05:02 PM
mazdasly75's Avatar
your right, at 13:1 you fail the emission test, but it takes 2 min to fix. So prepare your fuel map just before the test. Also for a better emission, retard your timing by 5 to 10 in the range of the test, it will raise the chance to pass.
Old 03-18-2007, 10:29 AM
I'll give it a go
satisfied
144
11-05-2018 04:05 PM
itsMikey
MSPNP
09-28-2015 06:40 AM
elior77
30
09-23-2015 06:38 PM
eunosgippa
09-09-2015 05:19 PM
Motorsport-Electronics
ECUs and Tuning
09-05-2015 08:02 AM
Quick Reply: AFR Targets
