How R you keeping the heat out of cabin?
Old Sep 17, 2013 | 11:31 AM
  #101
shlammed's Avatar
Total Cats: 51
solid info hyde.
I emailed Thermwell products about the foam **** you guys use. product number fv516 has a temperature rating of 190 degrees but the fiberglass is fire retardant.
So it will fall off but it wont burn. Probably OK to use if it will stick. (similar to what Hyde said)
Old Oct 16, 2013 | 05:13 PM
  #102
poobs's Avatar
Total Cats: -6
Originally Posted by poobs
Well, I drove all over today in 90 degree heat and the piece that I glued on top of my heat shield is still ok.
I'm going to slap some more when I get a chance.
See pic if it loads
Oh, BTW do not use this stuff directly on the heat shield.
Mine has not burst into flames yet but it got hard and somewhat brittle. The foil seems to be ok.
Old Oct 16, 2013 | 05:16 PM
  #103
Nagase's Avatar
Update. Put a fair amount of miles on my heat shielding on the transmission tunnel/firewall.
It's quite helpful and lasting well. Still recommend ceramic coating everything though.
Old Oct 16, 2013 | 05:51 PM
  #104
Total Cats: 1,924
The DEI Floor & Tunnel Shield II? I'm guessing you did the 3.5 sq. ft. chunk as in the video?
Thanks for the report back, first hand experience is a huge bonus. I'm thinking this is the route I'll finally take.
Old Oct 16, 2013 | 05:56 PM
  #105
Nagase's Avatar
I got this, actually:
DEI 050502 4' x 21" Floor And Tunnel Shield - 7 sq.ft : Amazon.com : Automotive DEI 050502 4' x 21" Floor And Tunnel Shield - 7 sq.ft : Amazon.com : Automotive
Put a chunk over the tunnel just like the video I showed before, then another square by the ebrake, and more by the headers.
Old Oct 16, 2013 | 06:11 PM
  #106
Total Cats: 1,924
Awesome. Does it mold well at all to the compound curves and such?
Old Oct 16, 2013 | 06:15 PM
  #107
Nagase's Avatar
It actually did surprisingly well. The only place where there's a gap in adhesion was on the ebrake, where it needs to go up and over two different levels. I could have cut it and put on both, but it's working fine with that gap even. Very nicely sticky.
The only prep I did was soap and water.
Old Oct 23, 2013 | 08:01 PM
  #108
HHammerly's Avatar
Total Cats: 63
Just finished putting some on my build, hope that it is worth the money
Attached Thumbnails How R you keeping the heat out of cabin?-null_zps53c4f432.jpg   How R you keeping the heat out of cabin?-null_zpsd287ad6b.jpg
Old Oct 23, 2013 | 08:13 PM
  #109
Nagase's Avatar
I'd put some on the ebrake area too. A surprising amount of heat comes in through there.
Old Oct 23, 2013 | 08:19 PM
  #110
poobs's Avatar
Total Cats: -6
Thumbs up
Looks like good stuff
U built your car in the shower ?!
Old Oct 23, 2013 | 09:44 PM
  #111
HHammerly's Avatar
Total Cats: 63
Yea, got some over the brake howsing; No shower LOL long story but in short i have a shop floor drain (shower drain from Lowes)
Old Oct 25, 2013 | 02:07 AM
  #112
L4nthonyl's Avatar
I have dynamat installed in the bay and in the interior. Helped out a lot.
Old Oct 28, 2013 | 12:01 AM
  #113
triple88a's Avatar
Total Cats: 1,830
Man finding rattles with the shiny stuff will be a pain in the ***, glue that **** on there good.
Old Oct 28, 2013 | 01:00 AM
  #114
mr_hyde's Avatar
Total Cats: 24
It wouldn't be the worst idea to pop a few holes at the corners and secure with some rivets and fender washers.
Old Dec 3, 2013 | 01:14 PM
  #115
Total Cats: 1,924
HHammerly: How many sq/ft did you buy to get that much coverage? I may order this week and see how it goes.
Old Dec 3, 2013 | 06:33 PM
  #116
HHammerly's Avatar
Total Cats: 63
I got the 4'x42" mat like the one on this link (no affiliation) http://www.stylintrucks.com/parts/fl...45050503-.aspx
And had some left over after making the brake master heat shield etc.
it was easy to install with the engine and tranny out, but it would be hard to do with them on
Old Dec 3, 2013 | 07:07 PM
  #117
Total Cats: 1,924
Killer, thanks for the reply. Ordered 14sq/ft this afternoon, along with some other stuff. I'm looking to get similar coverage and didn't want to short myself. It will sit for a while until the engine/trans comes out again, but that shouldn't be an issue.
I noticed that DEI has part numbers for both "Floor and Tunnel Shield" and "Floor and Tunnel Shield II" floating around out there. Both sets of part numbers are searchable and orderable on Amazon. I'm wondering why they revised the product? I bought the II FWIW
Also ordered DEI Cool Tape for the seams, because anything worth doing is worth overdoing
Old Dec 3, 2013 | 07:23 PM
  #118
HHammerly's Avatar
Total Cats: 63
Great, post some photos when you get it done
Old Dec 4, 2013 | 12:27 PM
  #119
t2couger's Avatar
Here's a solution for the transmission tunnel from a local miata shop.
Mainly works on street cars, so sounds like this is a cheap easy and effective way to go.
What it is: Floor & Tunnel Shield II - Heat & Sound Insulation 050501 | Purchase DEI, CryO2, Ny-Trex, Boom Mat & SPA Turbo Products | Design Engineering, Inc. - Thermal Performance Products
Where he's selling it: Miatamecca Insulation Heat Shield Floor Tunnel Cure for Miata MX 5 Hot Foot | eBay
I did this and used this in the car on drivers side and over transmission tunnel made a huge difference.
Old Dec 4, 2013 | 12:55 PM
  #120
Total Cats: 1,924
Is that Suppressor Acoustical & Heat Control Mat or Super Sonic Acoustical Mat ?
I'm pulling the dash this weekend and the plan is to run DEI - Under Carpet Lite over the tunnel and as far up the firewall as I can get it, and then follow it up with the before mentioned Floor and Tunnel Shield II on the outside next time the engine is out.
I have a roll of RattleTrap XXX in the garage I bought for my 70's F250 that I could press into service, but that ****'s heavy. I used some on the rear deck and vertical section behind the seats in the Miata and it helped a lot, but I'm not sure I want to use all 30lbs of the stuff.
