6 speed shifter help
Old Nov 2, 2013 | 04:48 PM
HHammerly's Avatar
Total Cats: 63
Default 6 speed shifter help
An some one identify which shifter goes on my new 6 speed ?
Thanks
Attached Thumbnails 6 speed shifter help-null_zpscfe8d1f7.jpg   6 speed shifter help-null_zps07fb005c.jpg
Old Nov 2, 2013 | 05:07 PM
JKav's Avatar
Total Cats: 47
The switch in the 6-speed shifter-related design ('early' vs 'late') happened in mid 2001 at VIN 220739.
Your 6-speed's VIN is early style. So you need the middle shifter.
The top shifter is for an later style 6-speed. The bottom one is for a 5-speed.
Old Nov 2, 2013 | 05:15 PM
HHammerly's Avatar
Total Cats: 63
JKav, thank you!!!! I knew about the changes on the shifter p/n's but could not identify them, really appreciate it.
Old Nov 2, 2013 | 06:38 PM
supercooper's Avatar
Total Cats: 35
Thats quite an odd thing to know.... But you definitely get props for knowing that!!!!!
Old Nov 2, 2013 | 09:09 PM
scenturion's Avatar
Total Cats: 61
Yeah, damn, props to you.
Old Nov 2, 2013 | 09:39 PM
JKav's Avatar
Total Cats: 47
I only know because I recently had to research it myself. Long story short, anybody need a brand-new, 'early style' 6spd shifter? Cuz I have one that I can't use...
Old Nov 3, 2013 | 12:18 AM
RotorNutFD3S's Avatar
Total Cats: 36
Yup, props to you. Was checking out the thread to potentially post the same info as I also had to go through the same thing with mine.
Old Nov 3, 2013 | 06:01 AM
NiklasFalk's Avatar
Total Cats: 63
Did Miataroadster do anything else than a larger tip bushing to be able to use the same shortshift kit for early and late 6speeds?
If that's the only difference you could just buy a hybrid bushing (small ball but larger Od, "shaft tip 15mm D, turret hole 21mm D").
Old Nov 3, 2013 | 08:50 AM
supersuckers's Avatar
Total Cats: -2
I may need a NB1 6-speed shifter.
Old Nov 3, 2013 | 03:16 PM
Failure's Avatar
Total Cats: -29
Just to help people out with the identification, 6 speed shifters are 3/16 shorter between the big ball and the small ball, and the big ball is bigger on the NB2 shifters. So:
NA 5MT: long shaft, small ball, one slit
NB 5MT: long shaft, small ball, two slits
NB1 6MT: short shaft, small ball, two slits
NB2 6MT: short shaft, large ball, two slits
Now we can all consider ourselves experts on shafts, *****, and slits.
Old Oct 31, 2017 | 01:32 PM
Long_av8r's Avatar
Sorry to dig up an old thread but, does anyone have approximate measurements of the *****? I pulled a shifter from my 6 speed and something doesn't seem right. My ball (I'm a one ball man and I'm off the rodeo...) measures 14.92mm, and the control rod end it goes into, without a bushing fitted, is 15.18mm. Does that sound right?
Old Oct 31, 2017 | 03:40 PM
Long_av8r's Avatar
Sorry about this, I had a noob moment and measured the wrong control rod end. But, between myself and the seller of the transmission I have (who is a stand up guy up in El Monte) we came up with some measurements.
90-05 5 speed shifter with bushing: 18.75mm
99-00 6 speed shifter with bushing: 18.75mm
01-05 6 speed shifter with bushing: 21.5mm
I hope my mistake can help someone else out in the future.
leatherface24
Cars for sale/trade
15
Oct 16, 2015 11:35 AM
zephyrusaurai
Meet and Greet
Sep 28, 2015 10:59 PM
Greasyman
Sep 28, 2015 10:44 AM
shanesauce
1
Sep 6, 2015 08:47 PM
