How are you strapping down your car?
Old Jan 31, 2014 | 03:21 PM
jeff_man's Avatar
Total Cats: 103
Default How are you strapping down your car?
All the factory tow points have been removed from the car and spec tow hooks added but you can't use them to secure the car on a trailer. I have been routing axle straps through my wheels to strap it down but an starting to think that is messing with my alinement. How are you all strapping down your cars on your trailers?
Old Jan 31, 2014 | 06:41 PM
miata2fast's Avatar
Total Cats: 175
I have been using the front and rear sub-frame braces as my tie down points.
At the drag strip, I actually remove the braces after I unload the car and reinstall them when I am ready to load the car back on the trailer. They are just unnecessary weight at the drag strip.
Old Jan 31, 2014 | 08:26 PM
ctdrftna's Avatar
Total Cats: 56
i used to go through my rear wheels, and I used the front hoop on my tube from with the bumper off, that doesn't apply to most thought.
Old Jan 31, 2014 | 09:57 PM
I put the tow hooks back on to tow it with. If they were good enough for it getting tossed around on the open ocean for 7000 miles and getting slammed around by some union crane jock, they're good enough for a trailer with suspension.
If I had a trailer with e-track I would use e-track loops over the wheels.
Old Feb 1, 2014 | 12:33 AM
jeff_man's Avatar
Total Cats: 103
I can install e-track, was thinking about that.
Old Feb 1, 2014 | 01:26 AM
Slowest Progress Ever
Total Cats: 305
Since I drift, I feel that there is no reason to strap my car down. I just pull on the 3' extended e brake handle and if it falls off the trailer, f^ck it. It'll look better with accidental damage than it will after my drift "race".
Old Feb 1, 2014 | 11:59 AM
EricJ's Avatar
Total Cats: 27
I'm using U-Haul trailers, they have straps over the front tires. I'm assuming two things:
1. This allows the car's suspension to handle the weight of the car.
2. Any stresses from bumps on the trailer, with it's suspension, is much less than hitting a curb on track at 70 mph.
Old Feb 1, 2014 | 09:42 PM
robertcope's Avatar
Total Cats: 11
I strap through the wheels. As EricJ mentions, the suspension is allowed to work without "working" the straps. Some folks are concerned that this will upset alignment, I can't really speak to that. Savington mentioned that he straps this way and the alignment does not move here: Miata tie down points on trailer [Archive] - MX-5 Miata Forum
robert
Old Feb 1, 2014 | 11:03 PM
No lift's Avatar
Through the wheels here. No problems ever. I also do not keep my car in gear, heard from a spec miata racer years ago that bouncing and rocking can blow the first gear in trans if you keep it gear. Don't know if that's true but never wanted to risk it!
Old Feb 2, 2014 | 10:37 AM
jeff_man's Avatar
Total Cats: 103
In my mind over the wheels is just holding the car down with out any side to side force. Through the wheels your putting directional force on the edge of the wheel away from the car. It's like putting your car in a vice and pulling the alignment and/or toe out of whack.
Now that could not be the case as I'm over thinking it and/or the alignment, toe set points are a lot stronger than I think.
Old Feb 2, 2014 | 03:09 PM
Nate99's Avatar
Slightly off-topic, but I'm renting a U-Haul for the NASA event next weekend... what do you tow that setup with?
Old Feb 3, 2014 | 05:31 AM
timk's Avatar
Total Cats: 37
Over the tyres here too (around the tread, not across it).
Old Feb 3, 2014 | 06:48 AM
Oscar's Avatar
Total Cats: 120
All our racecars are strapped down like this:
Attached Thumbnails How are you strapping down your car?-large_5894_0228011233.jpg
Old Feb 3, 2014 | 08:16 PM
EricJ's Avatar
Total Cats: 27
2013 F-150 Ecoboost w/ HD Payload and Max Tow. 11,300 tow capacity w/ 2,580 payload.
Get the 7 or 7.5. The fender folds down lower so you can open the Miata's door. The 6.5 is 2 inches taller. The trailers weigh 2,100lbs. My Miata is around 2,200 lbs. For a total of 4,300 lbs. But make sure you tell them you have a 8,000 lb hitch.
Old Feb 5, 2014 | 03:57 PM
jeff_man's Avatar
Total Cats: 103
Take your big money and get the **** out of my thread. Poverty tower with 2000 1/2 ton suburban.
Old Feb 5, 2014 | 09:49 PM
Ben's Avatar
Ben
Total Cats: 134
I loop long axle straps through the wheels when there is no good tie down point. The straps have soft sleeves over them to prevent wheel damage. I have never caused an alignment problem or scratched wheels with this method.
Old Feb 6, 2014 | 10:38 AM
jacob300zx's Avatar
Total Cats: 151
When there are no good tie down points I use the lower a arms front and rear, never had a problem that way for over 10 years and thousands of miles. With any form of strap always check them quickly within 30 miles. I use the big yellow industrial ratchets with no problems. Never, ever, even for a lawn mower, use those motorcycle slip cam straps. They have failed every time I've seen someone use them.
Old Feb 6, 2014 | 11:21 AM
Ben's Avatar
Ben
Total Cats: 134
Cam straps aren't suitable for holding down a car, but I use them all the time for dirtbikes and what not, never an issue. You have to make sure that the suspension is fully compressed or has a "shock saver" properly installed. I personally have never used a shock saver, and have never had a bike come loose or blown a fork seal.
Jike Spingleton
Cars for sale/trade
Sep 20, 2016 04:33 PM
Squiblez
Sep 22, 2015 10:17 AM
TheNomad
Engine Performance
Sep 21, 2015 10:20 PM
bigben
Sep 11, 2015 03:41 PM
Voltwings
Sep 11, 2015 08:23 AM
