SFBay: '99 built block, NB fuel rails, injectors
Old Oct 23, 2014 | 12:08 PM
scenturion's Avatar
Total Cats: 61
Default SFBay: '99 built block, NB fuel rails, injectors
Up for sale are some parts from our failed engine build. All prices are OBO.
SPEC SZ81A Aluminum flywheel. I actually can't find a weight spec, but the PO swears it's <10lbs. Friction plate worked fine despite the looks. New ones are available for $90, though.
Asking $190
MSM Master cylinder. Pulled from an 04 with 44k miles. 15/16" diameter, so great to reduce pedal travel on an earlier car.
Asking $25
Garagestar type 1 stainless front license plate bracket. For cars without fogs.
$35
VICS intake manifold. Includes throttle body. Great condition except for broken nipple on VICS solenoid.
Asking $65
VICS intake manifold, bare. Was going to polish.
Asking $25
Left NB1 tail light, with small crack.
Asking $15
NB1 AC compressor. Worked when AC was deleted.
Free with purchase
NB1 Alternator. Worked great.
$30
NB1 Injectors
Need a rebuild since the plastic caps got dented while in storage.
Asking $40
NB2 Fuel rail and injector harness
22k miles on these parts
Asking $40
NGK spark plug wires, little use.
Asking $10
BP4W dipstick without broken handle
Asking $7
NB2 (fits NB1 as well) crank damper with 4 tooth CKP plate.
The plate can be modified to give variable timing on an NB1
Asking $5
NB1 EGR pipe.
Free with purchase
Attached Thumbnails SFBay: '99 built block, NB fuel rails, injectors-6o3c2305.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2304.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2303.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2302.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2301.jpg
SFBay: '99 built block, NB fuel rails, injectors-6o3c2300.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2299.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2306.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2307.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2308.jpg
SFBay: '99 built block, NB fuel rails, injectors-6o3c2309.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2311.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2312.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2313.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2317.jpg
SFBay: '99 built block, NB fuel rails, injectors-6o3c2314.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2315.jpg   SFBay: '99 built block, NB fuel rails, injectors-img_20141025_165951.jpg   SFBay: '99 built block, NB fuel rails, injectors-img_20141025_165958.jpg   SFBay: '99 built block, NB fuel rails, injectors-img_20141025_170034.jpg
SFBay: '99 built block, NB fuel rails, injectors-img_20141025_165937.jpg   SFBay: '99 built block, NB fuel rails, injectors-img_20141025_170726.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2313.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2317.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2314.jpg
SFBay: '99 built block, NB fuel rails, injectors-6o3c2315.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2299.jpg   SFBay: '99 built block, NB fuel rails, injectors-img_20141025_170403.jpg   SFBay: '99 built block, NB fuel rails, injectors-img_20141025_170459.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2306.jpg
SFBay: '99 built block, NB fuel rails, injectors-6o3c2307.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2308.jpg   SFBay: '99 built block, NB fuel rails, injectors-img_20141025_170146.jpg   SFBay: '99 built block, NB fuel rails, injectors-img_20141025_170623.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2309.jpg
SFBay: '99 built block, NB fuel rails, injectors-img_20141025_170232.jpg   SFBay: '99 built block, NB fuel rails, injectors-img_20141025_170159.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2311.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2312.jpg   SFBay: '99 built block, NB fuel rails, injectors-img_20141102_172759.jpg
SFBay: '99 built block, NB fuel rails, injectors-img_20141102_172746.jpg   SFBay: '99 built block, NB fuel rails, injectors-img_20141102_173831.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2313.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2317.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2314.jpg
SFBay: '99 built block, NB fuel rails, injectors-6o3c2315.jpg   SFBay: '99 built block, NB fuel rails, injectors-img_20141102_173216.jpg   SFBay: '99 built block, NB fuel rails, injectors-img_20141102_173205.jpg   SFBay: '99 built block, NB fuel rails, injectors-img_20141102_172913.jpg   SFBay: '99 built block, NB fuel rails, injectors-img_20141102_173459.jpg
SFBay: '99 built block, NB fuel rails, injectors-img_20141102_173539.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2299.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2306.jpg   SFBay: '99 built block, NB fuel rails, injectors-img_20141025_170232.jpg   SFBay: '99 built block, NB fuel rails, injectors-6o3c2311.jpg
Old Oct 23, 2014 | 12:14 PM
psyber_0ptix's Avatar
Could I get that little knock sensor connector, long rectangle one
Old Oct 23, 2014 | 12:26 PM
gesso's Avatar
Total Cats: 276
Pm'd about the block
Old Oct 23, 2014 | 12:37 PM
The block is a steal if all you need is rings and a rehone. Seriously, that's under the cost of the pistons and rods themselves.
Old Oct 23, 2014 | 12:57 PM
scenturion's Avatar
Total Cats: 61
A coworker wants the block - consider it sold.
Old Oct 23, 2014 | 01:04 PM
Total Cats: 1,924
Curse you gesso!
Old Oct 23, 2014 | 01:09 PM
he better run ALLOFIT on dat exocet now
Old Oct 23, 2014 | 01:11 PM
Total Cats: 1,924
All 100kpa?
Old Oct 23, 2014 | 02:09 PM
scenturion's Avatar
Total Cats: 61
Amusingly, this was the block originally intended to go into gesso's exocet before the original owner gave up.
Old Oct 23, 2014 | 03:11 PM
Total Cats: 1,924
Haha, that's kinda funny. I thought this engine was setup for 11:1? Or is this not that engine? No idea how much stuff Larry accumulated, but I recognise his sickness as we have that in common.
Old Oct 23, 2014 | 03:41 PM
scenturion's Avatar
Total Cats: 61
He swears theyre 10:1 with an additional half point from the mods he did to the head. He does have quite a stash though. If there's anything else you know of that you want, let me know and I'll help him extricate it more quickly.
Old Oct 24, 2014 | 01:00 AM
k24madness's Avatar
Total Cats: 95
You got PM
Old Oct 25, 2014 | 03:23 PM
scenturion's Avatar
Total Cats: 61
Updated thread with a bunch more stuff
Old Oct 26, 2014 | 11:33 AM
scenturion's Avatar
Total Cats: 61
PMs replied
Old Oct 26, 2014 | 06:13 PM
Rajat's Avatar
Default NB1 fuel rail + engine harness end
Willing to ship to 29607?
Old Oct 27, 2014 | 11:22 AM
scenturion's Avatar
Total Cats: 61
Sure PM me which parts you want and I'll get a shipping quote worked up.
Old Oct 27, 2014 | 01:38 PM
Rajat's Avatar
Sorry I cannot PM yet, here is the pats info:
NB1 fuel rail and injector harness
Asking $40
and
Cut engine harness end
$Free
Old Oct 27, 2014 | 01:40 PM
Total Cats: 1,924
Thats the thing, I have no idea what else he has squirreled away I'll have to shoot him and email or stalk him on NCR for a while.
Old Oct 28, 2014 | 12:11 PM
scenturion's Avatar
Total Cats: 61
Some stuff is sold. Wish I could change the thread title
OBO!
Old Oct 28, 2014 | 12:21 PM
Total Cats: 1,924
Be careful what you wish for, lest some malevolent moderator grant that wish
