Raft 2.0
Old Aug 8, 2012 | 02:44 PM
  #141
viperormiata's Avatar
Total Cats: 283
I can't even explain how much better that looks than the last time I saw it.
This is win ****
Old Aug 8, 2012 | 03:27 PM
  #142
buffon01's Avatar
Total Cats: 13
Lol yeah, I also screwed the intercooler. No more ghetto band-aid.
Old Aug 8, 2012 | 05:05 PM
  #143
pusha's Avatar
Total Cats: -29
Look at that!
Old Aug 13, 2012 | 11:10 PM
  #144
buffon01's Avatar
Total Cats: 13
^Yeeee. Mazda Comp motor mounts are here. Install coming soon
Old Apr 14, 2013 | 03:32 PM
  #145
buffon01's Avatar
Total Cats: 13
It's been a while, but I did some work on the car today. I did a compression test and I must say that things when better than I expected
1 185
2 185
3 180
4 185
I also dropped some oil dye and chased the leak that has been haunting me.
It seems that front main seal is the culprit. I've done this job about three times already and it appears all three times was done incorrectly. I think this time I may get the install tool from flying miata and hope that way the seal is installed correctly.
This leak is causing oil to be splashed on the alternator and eventually chews up the belt. I am under the impression that due that there's no splash pan on the car, while on the road the wind helps that oil onto the belt then the belt spreads it out through the engine bay. I say that because I had the car running for a good amount of time and no oil was spotted on the alternator. Opinions?
Misc picture of the spark plug.
Attached Thumbnails Raft 2.0-img_1392_zps90e5c50d.jpg   Raft 2.0-img_1381_zpsf68b0fdc.jpg   Raft 2.0-img_1379_zpse9839af0.jpg
Old Apr 20, 2013 | 03:26 PM
  #146
buffon01's Avatar
Total Cats: 13
I got a new set of spark plugs in the car yesterday. I gaped them to ~0.020. Immediately after firing the car my idle was a lot leaner than before. The plugs I pulled out were gaped between 0.035-0.040 O_O
Old Apr 20, 2013 | 06:29 PM
  #147
more complete burn
Old Apr 20, 2013 | 06:40 PM
  #148
buffon01's Avatar
Total Cats: 13
more complete burn
Yeah, that explains the trail of smoke I used to get from time to time. I went for a drive and I can barely see any now.
This is the tune I currently have (it's **** I know) After the plugs I was able to at least go through the gears and adjust the VE table up top.
File Type: msq
Old May 14, 2013 | 10:05 PM
  #149
buffon01's Avatar
Total Cats: 13
The oil leak that has been haunting me for some time now has been fixed, hopefully for good. This is great news for now I can worry about improving the car. I have some competition mounts that will be going in the car this week
Here's the thread. https://www.miataturbo.net/engine-pe...-misery-72607/
excerpt
Old May 28, 2013 | 06:27 PM
  #150
buffon01's Avatar
Total Cats: 13
I added some insulation to the inside of the car is so much better in the cabin. i hope this would help long drives and drives around the city during the summer.
Old Jun 4, 2013 | 11:30 PM
  #151
buffon01's Avatar
Total Cats: 13
whale whale whale look what we have here
Attached Thumbnails Raft 2.0-86752d3b-0fe1-4c93-8013-3a3f2fcc8e7d_zps9942e077.jpg
Old Jun 5, 2013 | 02:09 PM
  #152
buffon01's Avatar
Total Cats: 13
Magnaflow is in. Only one word to describe it AWESOME!! It's just as quite as stock. Absolutely satisfied with the results :bigtu;
Old Aug 27, 2013 | 01:48 AM
  #153
sharkycarlos's Avatar
Nice build.
Old Apr 2, 2014 | 08:18 PM
  #154
buffon01's Avatar
Total Cats: 13
Slowpoke post. I just found out about virtual dyno. I knew what it was but since I have a test tomorrow I decided to mess with that instead.
The picture is from a 2nd gear, I couldn't do much more than that. The car is running is very rich up top. ML says 11.1 but my gauge read about ~2-4 below that. I guess I'll remove some up top and actually try to keep WOT all the way to 7k. The pictures doesn't look too good so the number are 198whp/200wtq at 10-12 psi It's a fun program
File Type: msq
File Type: msl
Old Apr 2, 2014 | 08:26 PM
  #155
Fireindc's Avatar
Total Cats: 915
3rd/4th would probably give more accurate results. The spool looks weak, but again.. 2nd gear pull isn't the best for showing spool characteristics.
The numbers are solid though. Also I just noticed your license plate says 420, and i lol'd.
Old Apr 2, 2014 | 08:39 PM
  #156
buffon01's Avatar
Total Cats: 13
2nd is the best I can do on the road. I may do some highway driving soon just to see.
Thanks I wish they were a little higher though. The license pate is completely unintentional haha
Old Apr 4, 2014 | 03:11 PM
  #157
buffon01's Avatar
Total Cats: 13
I think now I know why my previous set up felt quicker, and also why it blew up
19* of timing at back then ~15psi I'm stupid
Old Feb 8, 2015 | 06:57 PM
  #158
buffon01's Avatar
Total Cats: 13
Update and upgrade time
Old MS1 went so I upgraded to a MS2. I also got my hands in a bb t28 and I'm hoping the car will be much more responsive now. Pics and videos to come soon
mgeoffriau
Gaming
38
Mar 2, 2016 03:59 PM
graexodus
Oct 25, 2015 03:34 PM
TheNomad
Engine Performance
Sep 21, 2015 10:20 PM
twpipe
12
May 16, 2010 11:05 PM
reloader243
Apr 14, 2009 10:39 AM
