Bolt identification help
Old Mar 17, 2015 | 09:55 PM
kenzo42's Avatar
Total Cats: 13
Default Bolt identification help
Anyone know where this came from? Should be from a 90 miata.
Attached Thumbnails Bolt identification help-img95201503179518201295467_zps77306606.jpg
Old Mar 18, 2015 | 10:41 AM
psyber_0ptix's Avatar
Looks like the nut and bolt for a subframe brace or the small bolt of the PPF
You find the nut to match, or were they paired?
Old Mar 18, 2015 | 01:53 PM
kenzo42's Avatar
Total Cats: 13
They were paired.
I did remove the PPF. I also removed the rear subframe.
Where on the PPF are you thinking it belongs?
Old Mar 18, 2015 | 02:19 PM
If it came with the nut, it's probably not the PPF; but there are two long bolts and a short bolt by the transmission.
They look similar to a cross brace on the rear subframe, but that might have a welded nut on the subframe itself.
Is the tip of the bolt tapered?
Old Mar 18, 2015 | 04:18 PM
Miater's Avatar
Total Cats: 27
What size is the head? Is it sitting in the top of a jack stand?
With a lock washer and washer could be axle or drive shaft.
Old Mar 18, 2015 | 04:46 PM
Total Cats: 886
Drive shaft looks right to me.
Old Mar 18, 2015 | 05:19 PM
Wow, I guess the picture looked a lot stubbier than I expected, but yea, bolt and nut are two different sizes, then I'd also vote driveshaft.
Old Mar 19, 2015 | 02:00 AM
kenzo42's Avatar
Total Cats: 13
Better pic. Both bolt head and nut are 14mm. All bolts from the differential to driveshaft are accounted for. Any other ideas?
Attached Thumbnails Bolt identification help-bolt_zpsfypnqb6t.jpg   Bolt identification help-imageserve_zpsckoaha1w.jpg
Old Mar 19, 2015 | 07:03 AM
Is this a quiz? Will you tell us the answer if we cannot guess correctly?
#weightreduction
Old Mar 19, 2015 | 12:49 PM
Total Cats: 886
Is it a regular nut, or an oval-shaped, "squished" mechanical locknut? If a locknut, then it looks like an exhaust manifold nut, and in that case I think the bolt and nut are unrelated to each other.
Now that I can see the pointed end it's definitely not a driveshaft bolt. Some of the subframe bolts are that shape, but they aren't 14mm, so I dunno.
aidandj
Insert BS here
85
Nov 16, 2018 12:58 PM
Corky Bell
Prefabbed Turbo Kits
Nov 22, 2016 09:01 PM
Frank_and_Beans
Supercharger Discussion
13
Sep 12, 2016 08:17 PM
patsmx5
Oct 1, 2015 09:43 AM
