new engine
Old Mar 20, 2015 | 12:29 AM
DCsRECKLESS's Avatar
Total Cats: -11
Default new engine
I have a 1990 miata with a 1.8 swap and I through a rod and I'm at a cross road with what to do, rebuild with forced induction or Engine swap.
I'd be happy with reliable horsepower between 200-250
Leave a poscat -11 Leave a negcat
Old Mar 20, 2015 | 12:56 AM
ok
Old Mar 20, 2015 | 09:57 AM
Corky Bell's Avatar
Total Cats: 11
The right answer (s): a turbo 3 cylinder, or a 4.2 inline all aluminum six.
Old Mar 21, 2015 | 12:41 PM
calteg's Avatar
Total Cats: 41
I'd recommend a Packard V-1650. It's not a fuel miser, but hey, gas is cheap!
Old Mar 21, 2015 | 03:18 PM
cyotani's Avatar
Total Cats: 117
build a 1.6 for it.
Old Mar 22, 2015 | 10:06 AM
ryansmoneypit's Avatar
Total Cats: 458
His first post went pretty well.
Old Mar 22, 2015 | 02:04 PM
Stealth97's Avatar
Throughing rods is such a pain.
Old Mar 22, 2015 | 02:10 PM
Chooofoojoo's Avatar
Total Cats: 40
If you're building a replacement 1.6l, make sure to get the eggplant pistons.
Old Mar 22, 2015 | 09:34 PM
mx5-kiwi's Avatar
Total Cats: 57
Its a tough crowd here. Sometimes a little unfair but in this case....
Throwing a rod DOES suck but perhaps you might like to better ask a question in your post?
Old Mar 24, 2015 | 05:07 PM
wred's Avatar
Total Cats: 8
You "threw" a rod. Not "through."
No one is giving you a serious answer because no one is equipped to give you (a good) one. You haven't stated any goals, preferences or requirements/criteria for your decision, so we can't help you narrow down your choices.
On the other hand, the quality of your first post does say something. And based on that I'm going to recommend going with the simplest solution; buy another 1.8 from the same year miata that you got yours from and drop it in. Better yet, buy it from a vendor/shop and have them install it for you.
Old Mar 24, 2015 | 05:08 PM
OP are you considering an SR20 swap?
Old Mar 27, 2015 | 08:05 AM
Corky Bell's Avatar
Total Cats: 11
Sir, 404
Why do you quote me out of context? What does that suggest about you?
It is not necessary to know how a wastegate works to use it effectively. I'll stick with that.
I don't know how this computer works, but I use it..... well, sort of.....
I don't even know how my TIG welder works. Maybe that's the problem.
I don't know how my brain works either. Maybe if I used it more often I'd at least get a hint. Do your think you might be willing to try the same with your's?
corky
Old Mar 27, 2015 | 09:08 AM
Total Cats: 3,591
lol.
That is all.
Old Mar 27, 2015 | 09:11 AM
um.............
Old Mar 27, 2015 | 09:20 AM
Wut
Old Mar 27, 2015 | 09:24 AM
albumleaf's Avatar
Total Cats: 92
Smoke weed every day
-Corky Bell (Maximum Boost, 1997)
Old Mar 27, 2015 | 10:58 AM
Sparetire's Avatar
Total Cats: 36
I have a car. What should I do?
Seriously OP.
Let me ask you some questions:
1) What's the most common method people on this forum use to get between 200 and 250 HP?
2) What engine swaps are available to achieve that same HP?
3) What reasoning do people cite for their choices?
Hint: Take a look in the engine section. Also the build threads section. And most importantly, use the search tool. Searching for terms along the lines of "220WHP 1990 Miata" either on our search or even on the main Google page would be helpful to you.
If you take the 15 minutes to answer those questions, you will have learned a lot, and you will have your answer to your original question.
You are welcome.
Old Mar 27, 2015 | 11:11 AM
cyotani's Avatar
Total Cats: 117
The more and more I stick around this site the stranger Corky gets.
Old Mar 27, 2015 | 11:20 AM
it's concealer's fault
Old Mar 27, 2015 | 12:02 PM
glade's Avatar
Total Cats: 17
Originally Posted by Corky Bell
Sir, 404
corky
Today on national turbo-graphic, we watch as the elder fabricator slips further into dementia.
Watch as he attempts lure the younger tribesmen in, only to be thwarted by his own lack of self control.
Perhaps harkening back to days of his own youth, the elder opens his mouth...
