Skunk2 TB on MSM? Coolant lines...
Old Apr 8, 2015 | 10:49 PM
tazswing's Avatar
Default Skunk2 TB on MSM? Coolant lines...
Before I go port-matching I want to make sure this 64mm TB actually fits my 04' MSM. I am totally stumped as to how the coolant lines run on the new TB. I would appreciate either dummy guidance or confirmation that this is not the correct TB for the MSM.
Thanks.
Attached Thumbnails Skunk2 TB on MSM? Coolant lines...-20150408_183028_zpsc3pemhg4.jpg
Old Apr 8, 2015 | 11:16 PM
Lokiel's Avatar
All-round "Good Guy"
Total Cats: 266
Yup it fits, and NO there are no hoses attached to it - just shorten the existing ones and join them using an internal barb.
See my build thread below for details.
Attached Thumbnails Skunk2 TB on MSM? Coolant lines...-tbcoolanthosesa640x480_zps1b360249.jpg
Old Apr 9, 2015 | 12:10 AM
it eliminates the stupid throttle body "heater", and that's a good thing.
Just get a long hose and run from waterneck to oil cooler like everyone else.
Old Apr 9, 2015 | 12:17 AM
tazswing's Avatar
good god...that is a build thread
Thank you for the info! 8mm hose joiner coming up.
for the record i wish my ecu was under a floor panel.
Old Apr 9, 2015 | 12:18 AM
Total Cats: 1,410
If only there was a built MSM in your area with this exact setup you could check out...
Old Apr 9, 2015 | 12:24 AM
tazswing's Avatar
not sure exactly where those two points are but i like/get the idea.
wtf, TB heater? good riddance.
Old Apr 9, 2015 | 12:25 AM
tazswing's Avatar
i thought is was in peices still
Old Apr 9, 2015 | 12:32 AM
Total Cats: 1,410
Keep up man!
https://www.miataturbo.net/build-thr...r-83453/page3/
It's on with a "T" piece until I find a brass straight coupler. Just cut up the stock pieces a little bit on each. Zip tied the joint to the injector plug on the front of the engine, so it won't dangle into the belts.
Old Apr 9, 2015 | 12:41 AM
tazswing's Avatar
Keep up man!
oh bite me, i got a 4-week old...but i subscribed. besides, you will see my car again soon and let me know what i did wrong this time...lol.
Old Apr 19, 2015 | 10:40 AM
Mazdaspeeder's Avatar
Total Cats: 70
I have this same TB and no, there is no way to run coolant through it. I eliminated all of my lines when I did the coolant reroute and I just did not care to run them all over the place again. Then I found out what their purpose is and was glad I didn't bother hooking them back up.
I have not installed my TB yet either, need to remove the upper plenum and match it.
Old Apr 19, 2015 | 11:27 AM
Total Cats: 1,410
I've deleted the water lines all together on a few engine builds, The best method is a small piece of quality hose with a bolt in it, clamped of course.
However, I think it was Mobius who noticed the lack of oil warm up when it was deleted, and as important as oil is for an engine, it's temperature is just as important, and I'd rather have it warm up a little faster.
For my project MSM, I trimmed the hose going from the throttle body to the thermostat neck, and connected the two. I'd rather run a single piece of hose from the water/oil warmer straight to the thermostat neck, but that's a project for another day.
Old Apr 19, 2015 | 11:29 AM
Total Cats: 70
Interesting observation. One thing I noticed on my OP gauge is that even after driving for about 10-15 minutes, my oil pressure at idle is still higher than it will be after 30 minutes or so. Of course, I have the TDR sender kit which is OK but not hailed for it's response speed.
Old Apr 19, 2015 | 12:22 PM
tazswing's Avatar
Very interesting. I was lazy so it was just a brass barb and zip tie to keep the line out of trouble.
Attached Thumbnails Skunk2 TB on MSM? Coolant lines...-20150419_093455_zpsdiyc3btq.jpg
Old Apr 19, 2015 | 09:09 PM
leboeuf's Avatar
Total Cats: 57
Hmmmm throttle body ice buildup is a real thing for those who live in places where it freezes. What works in California won't work everywhere. There is a real purpose for the warmer.
Old Apr 19, 2015 | 10:53 PM
tazswing's Avatar
That is an interesting idea. What would freeze in the TB? Seems like if the TB is frozen there would be a whole lot of other stuff, too.
Good thing i live in Oregon and not Cal., though...
Old Apr 20, 2015 | 12:05 AM
Total Cats: 884
The throttle body can freeze in cold-but-not-freezing conditions because the ambient air pressure drops as it flows past the partly-closed throttle plate, and thermodynamically that results in a temperature drop, sometimes below ambient. Any moisture in the air can then freeze onto the throttle plate, resulting in a stuck throttle.
Old Apr 20, 2015 | 01:03 PM
tazswing's Avatar
This is why I love this sitesight!
Old Apr 21, 2015 | 07:04 PM
Lokiel's Avatar
Total Cats: 266
Originally Posted by tazswing
This is why I love this sight!
What are you looking at?
Old Apr 22, 2015 | 12:56 PM
tazswing's Avatar
People giving awesome answers that speak about " thermodynamically" thoughtful things. That is amazing. No sarcasm; it is why I really like this sitesight.
Old Apr 22, 2015 | 01:06 PM
Total Cats: 70
Maybe nobody understands because this is a SITE, not a SIGHT.
