Supertech vs Sealed Power VS855 Valve Springs
Old Mar 5, 2016 | 12:18 PM
Carloverx's Avatar
Default Supertech vs Sealed Power VS855 Valve Springs
I've been reading up on valve spring options for my turbo build.
Obviously the Supertech stuff is very popular
(Supertech Valve Springs 1.8 Mazda)
But it seems some people also use Sealed Power VS855:
(Sealed Power Valve Springs VS855 - Free Shipping on Orders Over $99 at Summit Racing)
According to some minimal feedback here, the VS855 can rev to the moon even under relatively high boost and work with stock retainers and keepers:
https://www.miataturbo.net/engine-pe...o-70450/page2/
So my questions is: What risks or drawbacks are there from running $120 Sealed Power springs (with my stock retainers and keepers), compared to $380 "Light Double Spring" Supper Tech setup?
This is my first thread, so go lightly
Old Mar 5, 2016 | 01:41 PM
hraday93's Avatar
Total Cats: 8
I would just go the supertech route and save the trouble.
perhaps my philosophy on modding is a bit self-righteous, but if there is knowledge of the "best" part around, and I'm not factoring cost in the term "best"... then you do what it takes to buy the best part.
I see a lot of guys who say "I don't have the cash for XYZ" and it baffles me that they have these big dreams and want to cut corners, whereas there are also a lot of guys who spend big bucks on something like an overflow tank for their naturally aspirated build and I tend to resonate with them more because they just seem to get it.
Again, it might be completely close-minded to want to always buy the perceived "best" parts but that's just my two cents on it.
Also, there will be droves of people who follow after me in this thread that will be able to shed a more detailed perspective on the pros and cons of both, lots of guys seem to have the spring game down and can tell you the ins-and-outs of what setup will benefit you, but you have to know what power you're shooting for among other things.
Old Mar 8, 2016 | 10:49 PM
Carloverx's Avatar
Thanks hraday93. I try to learn as much as I can about my options before making a decision.
To be honest, I expected either an insightful discussion, or to be flamed for not searching well enough, but surprisingly it's been quite.
Old Mar 8, 2016 | 10:58 PM
There's a non vocal (for fear of backlash from forum sponsors and mods) group of people whom have a major disdain for the supertech valve springs because they take a set and after some use seem to have significantly reduced seat pressure. I never noticed that problem with them in my motor, though I'm not sure I ran them long enough and I also havent measure the seat pressure currently.
Old Mar 9, 2016 | 12:16 AM
hraday93's Avatar
Total Cats: 8
Interesting. I guess we'll see what the heavy doubles do for me. Would those people happen to be running stock lifters too? I read some threads like that early on in my "lurking" stage that suggested the stock lifters created untimely wear in some setups.
Old Mar 9, 2016 | 12:29 AM
psyber_0ptix's Avatar
this concerns me
Old Mar 9, 2016 | 10:17 AM
dleavitt's Avatar
Total Cats: 223
This thread is relevant to my interests. I have a NB1 head to refresh.
Old Mar 9, 2016 | 10:24 AM
Downmented's Avatar
Total Cats: 80
this concerns me
Ditto
Old Mar 9, 2016 | 12:41 PM
Carloverx's Avatar
Additional information/feedback on VS855 here:
VS-855 valve springs - any long term usage reports ? - MX-5 Miata Forum
Old Mar 9, 2016 | 04:20 PM
albumleaf's Avatar
Total Cats: 92
Which exact springs are you referring to? Or is it all three options?
Old Mar 9, 2016 | 05:11 PM
NiklasFalk's Avatar
Total Cats: 63
Running ST heavy doubles with custom steel retainers.
Trying to explain the doubts about the Ti retainers (based on race engine failures) felt kind of pointless.
It's better to be a happy shopaholic, ignorance is bliss.
Old Mar 9, 2016 | 06:46 PM
hraday93's Avatar
Total Cats: 8
Originally Posted by Downmented
Ditto
Me 3.
And exactly what backlash is there to be had besides a hate cat and a possible sour look on the street if or when one ever meets these folks?
Old Mar 9, 2016 | 07:22 PM
Originally Posted by hraday93
Me 3.
Just that, its not worth arguing about on the internet over.
Old Mar 9, 2016 | 07:33 PM
hraday93's Avatar
Total Cats: 8
Reporting a problematic high performance part isn't worth it? Man, I'm a long way from home on the Mazdaspeed Forums.
Old Oct 30, 2016 | 10:00 PM
Carloverx's Avatar
Update:
The Sealed Power Valve Springs VS855 are in the car and seemingly working fine for the first 100 miles or so.
No really power/revs have been put through them yet, so will keep you posted.
Old Oct 30, 2016 | 10:08 PM
hraday93's Avatar
Total Cats: 8
Well my motor has been running decent. as most know, no boost on it yet. I'm still under 800 miles on the build too. Best believe though if any of the mentioned problems arise, I will happily take one for the team and call them out.
It's not like I get much response to my questions anyways, so getting booted is of little significance if a problem can be fixed for the community. I'd say that should fall on Braineack for doing the right thing in the long run.
Old Nov 4, 2016 | 04:25 PM
AndrewG's Avatar
Total Cats: -4
I just jumped on those as well. I´m going to run custom grind 10mm lift cams Supertech valves and supermiata solidlifters...do you guys know if those lifters work with stock valve retainers ?
Old Nov 4, 2016 | 04:34 PM
Total Cats: 1,870
Lifters do not interface with valve retainers. They ride on the top of the valve. You will need shims for the lifters.
Be careful about higher lift cams and non stock springs. You can potentially run into coil bind.
Old Nov 4, 2016 | 05:11 PM
NiklasFalk's Avatar
Total Cats: 63
Hm, you always need to be careful when playing with the valve-train. You will not be safe from issues by staying with stock springs (creative misinterpretation).
Valve-train is one of those things that's depending on a little too many parameters to be a candidate for webshop, install and forget (like e.g. rods).
On top of just making things work the perception of "working" is very different.
I have springs that don't float valves even at 10.3k, so it works, but softer springs would be better in the long run since I seldom go past 8k.
You goals should dictate you design. Others choices might be relevant, but you have to get enough info to judge if they are.
Old Nov 4, 2016 | 05:12 PM
Total Cats: 1,870
Yes you can put it that way. But its even more likely with a super stiff (if stiffness was increased by increasing wire thickness) springs.
